Old 05-30-2009, 04:59 PM   #1
thakiller009
thakiller009 is on a distinguished road
Default freeze plug
could someone tell me where the freeze plug is located at on my 1990 supra if so could you give me a pic thxs
thakiller009 is offline   Reply With Quote
Old 05-30-2009, 09:06 PM   #2
Bill UK
AEM EMS
Bill UK's Avatar
Some info here Link & Link and a photo of the intake side below.
Old 05-30-2009, 09:12 PM   #3
mirage83
Here's a pic of the turbo side.
If you have to replace any, go with ones from Toyota. Some of the AM others which are available tend to be undersized. You won't be able to get them to seat properly, and they WILL leak.
Old 05-30-2009, 09:32 PM   #4
Bill UK
AEM EMS
Bill UK's Avatar
Nice one mirage83, I know there’s one at the back, the cygnus1 also shows one at the front, buy I can’t remember see that one.
Old 05-31-2009, 04:41 AM   #5
thakiller009
k thxs for the help
Old 05-31-2009, 05:45 AM   #6
mirage83
You have one that's leaking Killer? If so, when you get ready to install the new one find something only slightly smaller than the ID of the new plug to hit to seat it. A single hit is best, as multiple hits tend to stretch the metal somewhat making a good seal difficult to get and you end up with another leaking plug. Some guys have fashioned custom tools to do the job, others use wooden plugs to seat the metal one.
Old 11-22-2009, 05:48 AM   #7
cvbikeguy
cvbikeguy's Avatar
thank goodness for this post. i just got an 86 today and turns out it has a leak. how bad is it to fix? its a pretty tight spot....
Old 11-22-2009, 01:31 PM   #8
mirage83
It's a relatively easy fix, you've just got to get the proper plug from Toyota (I don't recommend an aftermarked plug) and have enough room to swing the hammer to seat the plug. If the engine is in the car you may end up having to pull some hardware off to get the space you need.
supra ecu plug help please nzskate MKIV Supra 3 11-18-2009 01:52 AM
Transmission filler plug elsleepster Non-Generation Specific Questions 3 11-02-2008 04:44 PM
plug locations for injectors kidthunder650 MKIII Supra 1 06-05-2007 04:36 AM
Plug or hose came off back of block f00g00 MKIII Supra 3 05-20-2006 11:01 PM
new mk3 owner, spark plug galley full of oil!???? katillidie MKIII Supra 6 03-24-2006 05:09 AM
