Old 06-01-2009, 04:48 PM   #1
GettaRobo
GettaRobo is on a distinguished road
Default Headlight Wattage
Hi guys, just have a quick (potentially dumb) question for someone. I've got an 88 supra non turbo with a crappy $40 H4 headlight conversion kit and I've been looking everywhere for whether or not I'd be able to throw some 100W bulbs in or not. I was just curious if there'd be a problem with melting wires and such as that would not be very fun to deal with (I've only had this car for 6 months so I'm still learning how everything breaks... I mean... comes apart.) Any help would be greatly appreciated. Thanks
P.S If this has already been answered, I apologize
GettaRobo is offline   Reply With Quote
Old 06-01-2009, 07:15 PM   #2
mirage83
Yes, you can run 100w bulbs, but there's something to do before you run them... do a good rewire job for your headlights with heavier gauge wiring. Maybe install a good relay as well. The 20 year-old wiring for our stock headlights isn't good enough for reliable, thorough illumination with even our stock headlights, much less a high-watt set of H4 bulbs. Do the rewire first, test the results and then decide if you need to go with the 100's.
Oh, depending on how cheap and poor quality your housings are, you might want to invest in a good set of housings, probably Hella or Cebie. Cheap housings usually do a lousy job of proper light dispersal and control.
Old 06-01-2009, 07:43 PM   #3
GettaRobo
Thanks, I'll have to try that when I'm feeling brave enough. I'm almost scared of breaking something as it is a 20 year old car. I do, however, have a parts car so if I'm really worried about it I suppose I could perform experiments beforehand. One thing I've definitely found (mainly from disconnecting the horrid factory alarm) are the very tight spaces that the components like to hide in. For a big person such as myself, it is quite challenging. Back to being more on topic, I know that I'll be able to find the location of the relay in the online TSRM manual, but is the wiring relatively easy to follow? Or is it a pain in the butt like everything else? Thanks again!
Old 06-01-2009, 08:58 PM   #4
Bill UK
AEM EMS
Bill UK's Avatar
As Mirage83 said check the wiring first especially the bulb holder, I replaced mine with these .See post 10 Link other links Philips Rally H4 90/100W and Philips Rally H3 100W for the front fog lights. I've been running them for about 5 years with the same bulbs no problems.
Old 06-01-2009, 09:07 PM   #5
Bill UK
AEM EMS
Bill UK's Avatar
One thing I should have said in the other thread (# 10 posting) is that the part # CIBIE CIB082463 (H4) R180 is for a UK right-hand drive supra.
Old 06-01-2009, 10:47 PM   #6
GettaRobo
Thanks for the tips guys, I'll give it a shot and see what I can come up with.
1985 Toyota Supra Headlight Switch t4yl0r10 Shops & Part Reviews 0 01-15-2009 04:39 PM
MKIII Headlight Problem Supra275 Non-Generation Specific Questions 4 09-05-2008 09:06 PM
Flip headlight conversion?!?! dannydavi MKIII Supra 3 03-18-2007 12:25 PM
Headlight Ground-Wire Issues (YAY!) panda-supra MKII Supra 5 09-14-2006 04:01 AM
1983 Headlight Motor scorpmatt MKII Supra 3 12-07-2005 02:36 AM
