Old 06-07-2009, 06:37 PM   #1
Clorox9
Clorox9 is on a distinguished road
Default Piston rings
I was wondering if you can just drop the oil pan easily in the car. After head is pulled. Can the Pistons be dropped below easily. Also is there any special tools needed besides the basics?
Clorox9 is offline   Reply With Quote
Old 06-07-2009, 07:21 PM   #2
Bill UK
AEM EMS
Bill UK's Avatar
No, The front cross member is in the way, the sump needs to be lowered enough to clear the oil strainer protruding form the bottom of the block. I've only done it with the engine out, although I have read its possible to dismantle the cross member or lift the engine enough to remove the sump. Personally I would pull the engine, less hassle. (Location UK Sussex)
Old 06-07-2009, 08:10 PM   #3
Bill UK
AEM EMS
Bill UK's Avatar
There’s the culprit.
What type of Rings for NOS? abhattan MKIII Supra 1 03-20-2008 11:27 PM
Bhg vs worn rings vs valve guides Kuban MKIII Supra 22 04-23-2007 02:18 AM
1jz & 2jz Piston Rings joolhamdi MKIII Supra 4 04-14-2006 02:44 AM
