Old 06-08-2009, 11:33 PM   #1
jkendall86
jkendall86 is on a distinguished road
Default EGR malfuncion?..Water in Intake, BHG...
I recently did a head gasket replacement on a 7MGTE. When finished, I started the car and water was bubbling out between the exhaust manifold and the head. I decided that I had not connected something correctly so I took it all apart and start over. When I got the upper intake manifold off, I noticed water sitting in each of the openings. When I got the turbo off, I noticed water sitting in the exhaust side as well. After doing some research, I was wondering if anyone had experienced the bolt in the EGR chamber at the back of the head coming loose to allow coolant to flow to the exhaust and intake sides? Or what else could I have done wrong? Thanks.
jkendall86 is offline   Reply With Quote
Tags
bhg, blown, exhaust, intake, water
Won't suck the water from overflow illusive38 MKIII Supra 7 05-24-2012 09:19 AM
Where the h--- is the water going??? illusive38 Non-Generation Specific Questions 1 05-27-2008 03:23 AM
Where the h--- is the water going??? illusive38 Non-Generation Specific Questions 0 05-26-2008 09:27 AM
WAter not going back to raditor from recovery tank Help Jeff_5_7 MKIII Supra 12 09-15-2006 03:49 AM
