Old 06-10-2009, 12:51 AM   #1
88WhiteMKIII
88WhiteMKIII is on a distinguished road
Default engine makes knocking noise..
I have a fresh rebuilt 7mgte and when i turn the car on it has a knocking noise. almost like a rod knock...when you rev the car fast the car also does the noise. but while driving the car anything above 1500 rpm with smooth acceleration the noise is not there. also sounds like its coming from the top of the motor. any ideas guys?
88WhiteMKIII is offline   Reply With Quote
Old 06-10-2009, 05:18 AM   #2
87MK111Supra
87MK111Supra is on a distinguished road
I have the same thing. When I start the car I hear a little bit of rod knocking just for a quick second. As I rev the engine to about 2500-3000 rpms I hear a high speed fluttering sound that seems too quiet to be knocking. I went and had it diagnosed and they said that it could be the seals but the engine probably needs to be rebuilt. I hope it's not the case but that's what I've come to.
87MK111Supra is offline   Reply With Quote
Old 06-10-2009, 08:17 PM   #3
NevvBy
NevvBy is on a distinguished road
did u guys change the oil recently? If u didnt have the problem before, try changing the oil filter. Sometimes brand new oil filters are faulty and can cause that knocking noise at startup or low rpm. Sounds funny, but i had that problem after an oil change.
NevvBy is offline   Reply With Quote
Old 06-10-2009, 08:35 PM   #4
Bill UK
AEM EMS
Bill UK's Avatar
Check out post 2 & 3 in Link.
Old 06-10-2009, 09:09 PM   #5
dannydavi
dannydavi's Avatar
If it sounds like this...Click Here!
... stop driving it
I would fast forward to the last time marked in the notes section if you wanna just hear the sound.
This just happened to mine on Monday, and on Tuesday it broke down and the Crankshaft is seized up.
'86.5 Supra - A/T - N/A - JDM
Useful Sites:
ToyoDIY.com
ToyotaPart.com
MKIIITSRM
85 engine noise long-cat MKII Supra 0 12-03-2008 08:02 PM
Supra makes wierd rattling noise after 3000 rpm on every gear HELP! 89MkiiiSupra MKIII Supra 5 08-20-2008 03:53 AM
please help engine knocking red_armie_soviet MKIII Supra 1 09-30-2007 01:28 AM
engine knocking red_armie_soviet Non-Generation Specific Questions 1 09-28-2007 10:06 PM
HELP! My engine just started a weird noise... idoke MKIII Supra 12 10-05-2006 05:06 PM
