Old 06-14-2009, 04:31 AM   #1
bahamutmaster
bahamutmaster is on a distinguished road
Default car diedon the interstate help!!!!!!!!!
ok, so here i am, plodding along, car is doing great after a head gasket job. did everything right on the head gasket and i know i didnt blow the head gasket cuz it wasnt blowing white smoke or anything. what did happen was i was doing 70 on the highway and out of nowhere, the car stopped accelerating. it just rolled to a stop. afterwards it didnt want to start up. it just turned over and did nothing. so i was wondering, what could it be? ithought it might be my ignition coil, my fuel pump, or my timing belt. anyone have any ideas?
bahamutmaster is offline   Reply With Quote
Old 06-14-2009, 05:09 AM   #2
86.5 7MGE
86.5 7MGE's Avatar
That's a good start you can also try checking your plugs I have had cars stop running all of the sudden and it was the plugs, besides the #3 gasket has a tendancy of leaking out oil into the plugs and fowling them out. It's a 14mm hex key by the plugs.
Cold Air Intake
MIZU Aluminum Radiator
Ralco RZ Underdrive Pulley
NGK Wires and Plugs
Hi Flow CAT
MR Muffler
Super Coil
Techna Fit Brake lines
Clear Corner Turn Signal Lens
Projector Head Lights
Evo Fog Lights
Evo Body Kit
Soon ---> 3'' Exhaust
Old 06-15-2009, 02:55 AM   #3
mikeoc1
mikeoc1 is on a distinguished road
if it just shut off, I would check for broke timing belt first, then fuel pump, then ignition, ect.
mikeoc1 is offline   Reply With Quote
