Old 08-02-2005, 07:37 PM   #1
daiagaru2
daiagaru2 is on a distinguished road
hello,i'm curiouse about the trd 160 degree thermostat .i solo race my 1jz-gte supra i have upgraded the radiator to a koyo racing unit.is there any one in here that runs a 1jz-gte with a 160 degree thermostat and the stock ecu?i here that for some cars you have to alter the ecu to compensate for warm up programming.i hope thats not the case here.i run in hot weather ,above 100 degree track temps sometimes.i need to know if the ecu needs to be altered to run the lower temperature thermostat.thanks for your time and patience.
daiagaru2 is offline   Reply With Quote
How much HP can a stock 1JZ engine handle? Sperstad MKIII Supra 1 07-06-2010 06:58 AM
installing thermostat sd88supra MKIII Supra 8 06-18-2010 02:23 AM
Boost and Stock Fuel collink MKIII Supra 5 03-26-2008 11:43 PM
Checking Thermostat scruffboy Non-Generation Specific Questions 6 03-09-2006 05:49 PM
