Old 06-22-2009, 12:22 AM   #1
lacrosseg64
lacrosseg64 is on a distinguished road
Default Oil leak
Its leaking from the nut on the oil pan, is there supposed to be a brass washer that goes there like other cars? when I took it off it had some sealant on it. Also I just got the car a week ago and know nothing about yota's so sorry for the stupid questions.
lacrosseg64 is offline   Reply With Quote
Old 06-22-2009, 12:53 AM   #2
86.5 7MGE
86.5 7MGE's Avatar
Cool
No not a washer but a oil pan nut gasket you should be able to purchase this at the local parts store it sounds like the perfect time for an oilchange. And by the way threre's no stupid questions only the ones that you didn't ask and are going to pay for at the end.
Cold Air Intake
MIZU Aluminum Radiator
Ralco RZ Underdrive Pulley
NGK Wires and Plugs
Hi Flow CAT
MR Muffler
Super Coil
Techna Fit Brake lines
Clear Corner Turn Signal Lens
Projector Head Lights
Evo Fog Lights
Evo Body Kit
Soon ---> 3'' Exhaust
Old 06-22-2009, 04:44 PM   #3
lacrosseg64
Lol just changed the oil, it was really ugly. so i changed it and its leaking now. and i have the nut but when i took it off it had like liquid sealant on it or something. now im going to have to drain it again and put that on the nut lol.
Old 06-22-2009, 07:59 PM   #4
86.5 7MGE
86.5 7MGE's Avatar
You can use a hi temp gasket maker (black).
Cold Air Intake
NGK Wires and Plugs
Hi Flow CAT
MR Muffler
Super Coil
Evo Fog Lights
Evo Body Kit
Old 06-23-2009, 07:40 AM   #5
lacrosseg64
I fixed it with a 18mm gasket for the bolt. works just fine. but thanks for the impute ill definatly need more help as I find more problems
Heater Union (Coolant Leak) slader99 MKIII Supra 11 12-28-2009 12:29 AM
88 Non-Turbo coolant leak Tazman3653 Non-Generation Specific Questions 1 03-30-2009 02:09 AM
Coolant Leak bossman MKIII Supra 2 04-12-2008 09:31 PM
Oil Leak Question kidsusukigsxr Non-Generation Specific Questions 2 06-26-2007 03:17 PM
gas tank leak burton51m MKIII Supra 14 11-24-2006 06:16 PM
