-   -   Possible blown head gasket (http://www.toyota-supra.info/forums/mkiii-supra/14312-possible-blown-head-gasket.html)
lacrosseg64 07-04-2009 06:23 AM
So started with water leaking everywhere to white smoke coming from the engine to leaking oil and oil on the spark plugs. if anyone has anything that would help thanks
mirage83 07-04-2009 04:55 PM
Water leaking everywhere? Can you be a little more specific, try and identify just where it's coming from? There's a BUNCH of lines running around the engine which could be culprits.
If you've got white smoke coming out the exhaust, that's probably water entering the cylinders. BHG.
As with the water, exactly where is oil leaking from the engine?
The oil on your spark plugs, is it in the spark plug valley where the plug boots are or on the business end of your plugs?
Sorry for all the questions, but it'll make it easier to figure out what you've got going on.
lacrosseg64 07-04-2009 06:03 PM
No problem, it was late and I was tired when I asked. white smoke came really from everywhere like it over heated. oil was around the block water was back by the trany and just on the boots, didnt have really any tools with me when it happend. at least it was at in and out though ahaha
