So started with water leaking everywhere to white smoke coming from the engine to leaking oil and oil on the spark plugs. if anyone has anything that would help thanks
Water leaking everywhere? Can you be a little more specific, try and identify just where it's coming from? There's a BUNCH of lines running around the engine which could be culprits.
If you've got white smoke coming out the exhaust, that's probably water entering the cylinders. BHG. As with the water, exactly where is oil leaking from the engine? The oil on your spark plugs, is it in the spark plug valley where the plug boots are or on the business end of your plugs? Sorry for all the questions, but it'll make it easier to figure out what you've got going on. |
No problem, it was late and I was tired when I asked. white smoke came really from everywhere like it over heated. oil was around the block water was back by the trany and just on the boots, didnt have really any tools with me when it happend. at least it was at in and out though ahaha
Blown Head Gasket Symptoms! | Dejvid1785 | MKIII FAQ | 76 | 04-24-2011 07:59 PM |
Blown Head Gasket Snake Oil | unkymurch | Non-Generation Specific Questions | 21 | 08-06-2010 02:11 AM |
1989 Supra blown head gasket | rayk5799 | Non-Generation Specific Questions | 6 | 05-18-2009 10:51 AM |
Update: Blown Head Gasket Snake Oil - 8 months later | unkymurch | Non-Generation Specific Questions | 3 | 12-17-2008 09:35 PM |
Blown head gasket? | h8z2luze | MKIII Supra | 30 | 06-03-2006 03:18 AM |
