Old 07-15-2009, 11:26 PM   #1
carl johansson
carl johansson is on a distinguished road
First place I would look is the throttle position sensor - but to tell you the truth I don't even know if the supra has that. Alot of high performance shope sell a bogus "power enhancer" that is a throttle position switch that tells the computer that you are at full throttle - when you are only at 3/4. doesn't really add power - the petal still goes full - just no gain after3/4 throttle.
This problem sounds like the switch is working backward for some crazy reason! Like I said - it's a shot in the dark - but if someone burned a performance chip and it got screwed up - this could be the issue!
AFAIK - The Rev limiter on this engine is burned on the ECU chip! ( we hit it on occasion in the lemons racecar!)
Carl Johansson
carl johansson is offline   Reply With Quote
Old 07-15-2009, 11:28 PM   #2
GettaRobo
GettaRobo is on a distinguished road
Well, to tell you the truth, the TPS has already been looked at. Unless the new TPS they brought in was screwed, it's working fine. Thanks for the suggestion though.
GettaRobo is offline   Reply With Quote
Old 07-16-2009, 02:30 AM   #3
carl johansson
sorry,
didn't read all of the posts carefully enough. So if the TPS is OK - does this thing have a stock chip in it? Have you tried switching out the ECU with the one on the parts car?
Old 07-16-2009, 03:00 AM   #4
GettaRobo
Yes, I knew I forgot to mention something! The parts car is a manual, but the ECU works fine with the auto and I think it shifts slightly better with the manual ECU. On a side note I'd like to point out that I started having these problems before I put the other ECU in, so I doubt it's the reason.
ABS Problem? rasclaat_98 MKIII Supra 6 12-13-2010 09:53 PM
another heater problem nicnet MKIII Supra 16 12-05-2007 10:18 PM
found the problem brs86supra MKIII Supra 0 05-02-2006 03:42 PM
Boost Problem, I Guess nonstop213 MKIII Supra 0 02-23-2006 07:32 PM
