Old 07-08-2009, 11:18 PM   #1
Bhogal
Bhogal is on a distinguished road
Question Lights Issue
I have recently purchased a Mk III Supra and the lights are doing exactly what the manual says it should do with the headlight switch lever settings:
FIRST CLICKSTOP: No operation.
SECOND CLICKSTOP: Only the parking, tail, license plate and instrument panel lights turn on.
THIRD CLICKSTOP: The headlights also turn on.
However, can anyone tell me how I can get the front sidelights working on the ? The fron fogs work fine and main headlights with popups work fine.
Thanks.
Bhogal is offline   Reply With Quote
Old 07-09-2009, 02:00 PM   #2
GettaRobo
GettaRobo is on a distinguished road
It sounds like you have burnt out lights... Try replacing them. Unless I really misunderstood the question.
GettaRobo is offline   Reply With Quote
Old 07-09-2009, 04:19 PM   #3
Bhogal
Default Re:
Its what I have been thinking. You didn't mis-read, and hopefully I made it clear...might have been a bit akward to read, but basically the white bumper lights are not comming on. Indicators and main headlights are fine. Also, fogs and high beam is fine too, along with taillights. I thought I might be doing something wrong as it does not mention the bumper lights in the manual at all.
I will try, thanks.
Engine Run-on Issue gottadiesel MKIII Supra 1 04-02-2009 07:26 AM
LF: Lightbulbs guide lamw001 MKIV Supra 2 09-18-2008 02:23 PM
Brake lights not working! lifesnotfair MKIII Supra 18 05-05-2008 11:40 PM
Dash lights Furious1 MKIII Supra 5 03-30-2007 05:50 PM
