Old 07-21-2009, 10:12 PM   #1
SidewaySupra
SidewaySupra is on a distinguished road
Default Help! no idea whats wrong
Hey guys, I bought a clean 89 supra a month ago its na and its got 71000 miles on it. Heres the problem:
A couple times my car hasnt started right away I thought the clutch wasnt in all the way cuz id turn it a couple times and it would start. When it doesnt start it doesnt even turn over. Last night I drove to work about 30 minutes in 85-90 degree weather and the car drove fine. A few hours later i unlocked it and opened the door the alarm went off and it wouldnt start. I assumed it was because of the alarm but i reset the alarm and everything and nothing worked. after 20 minutes I gave up trying to start it regularly and flintstoned it. (had people push the car and pop the clutch) that worked and it drove fine. As I was driving though there was a high pitched whining noise that got louder as the revs got higher. There was a funny smell its hard to describe but no smoke. Could this all be a problem with the alternator? I read somewhere that the problem starting is an old trigger wire that isnt as conductive as it used to be because its old and hot. but that doesnt explain the sound and smell.
Has anyone else had this problem? I need help please
SidewaySupra is offline   Reply With Quote
Old 07-21-2009, 10:27 PM   #2
GettaRobo
GettaRobo is on a distinguished road
I have had a similar problem with the car not starting with my 88. Basically, I ended up removing the car alarm computer and grounding the blue wire with an orange stripe. A temporary fix would be to remove the radio fuse under the hood of the car (the second row of fuses in the middle, it's either 20 or 30 amp.) As for the noise and smell, I have no idea
GettaRobo is offline   Reply With Quote
Old 07-22-2009, 02:03 AM   #3
Conga1991
Conga1991 is on a distinguished road
i had the same problem with the car not starting, pushing it was the only way for my 88 supra to drive. make sure both doors are unlocked, that should work. i had one door locked and the other unlocked and it wouldnt start. try it and if it works then YAy!! lol
Conga1991 is offline   Reply With Quote
Old 07-23-2009, 08:39 PM   #4
mk3
mk3 is on a distinguished road
If your alarm goes off and your car doesn't start its because the supra has a killswitch to deactivate it you would have to close your door lock it and then unlock it with your key and it should turn on again
i had this problem like 2 times
mk3 is offline   Reply With Quote
Old 07-24-2009, 07:12 PM   #5
Bill UK
AEM EMS
Bill UK's Avatar
“High pitched whining noise, There was a funny smell, wouldn’t start ”. Sounds like the alternator belt slipping, also check the battery for DI water, just in case it’s fried.
Old 07-25-2009, 09:18 AM   #6
cheshire1369
cheshire1369 is on a distinguished road
ok all that is good for a temp fix, but however after having one with 188,000 miles, and two clutch plates, there is a good place to start for a more perm, alt. if the car does not register that the clutch is ALL the way in, it just assumes it's not in. clutch plates wear, the more they wear, the less "pedal" you have when you push in the clutch. my last one had less than half an inch, which is GREAT for speed shifting, but plays havoc on the internal alarm system. bty it had 75,000 whaen i got it, i had it three years, and only replaced the clutch plate and one rotor, keep the oil, filters, and plugs changed and you cant kill 'em! (side note...don't tell the cops, drove from denver to atlanta at 120mph just stopping for gas...LOVED IT !)
cheshire1369 is offline   Reply With Quote
Audio and a lot of other things wrong with car bluemeate MKIII Supra 4 05-18-2010 07:07 PM
new here. intrestin idea fullmetal MKIII Supra 14 07-25-2009 09:26 AM
My friends turbo idea RussianMK3 Off Topic Forum 4 01-16-2008 06:38 AM
carfax report. (sorry earlier posted to wrong category) supramkiiiboost Non-Generation Specific Questions 0 09-21-2007 10:45 PM
intake manifold has coolant what did i do wrong? 91toy supra MKIII Supra 6 09-16-2006 02:46 PM
