Old 07-29-2009, 04:40 AM   #1
86.5 7MGE
86.5 7MGE's Avatar
Exclamation Coolant Draining into Spark Plug Gulley
I have a 86.5 7MGE with minimum mods. It just happened recently but I have changed out my hoses about two months ago cause a few were cracked and just today I noticed that I have coolant in the back gathering near my #5 and 6 plug wells. I seen coolant leaking out of the inch size hoses I replaced on top of the valve covers that has an h pipe going to the throttle body and was wanting to know if anyone else has had this problem. This is the first time I have came across any problems with my Supra that I couldn't figure out for myself. Any advice is appreciated thanks
Cold Air Intake
MIZU Aluminum Radiator
Ralco RZ Underdrive Pulley
NGK Wires and Plugs
Hi Flow CAT
MR Muffler
Super Coil
Techna Fit Brake lines
Clear Corner Turn Signal Lens
Projector Head Lights
Evo Fog Lights
Evo Body Kit
Soon ---> 3'' Exhaust
Old 07-29-2009, 11:41 AM   #2
mirage83
Not sure on an N/A, but are there small coolant bypass lines going to your TB like there are on a turbo model? And check your heater lines which run from the back of the engine to your firewall.
Old 07-30-2009, 02:01 PM   #3
87mk111
87mk111's Avatar
I blew that same line on my supra. You'll need to replace it. After u replace it, pull ALL wires of ur spark plug wires. There will probably be coolant in all 6 of the holes, it looked like it was only in the #2 and 3 on mine, but they were all full. Next, take a shop vac and suck the water out. Then put thw wires back in, top off the coolant, and start it up. Make sure to check for leaks after u start the car back up.
Old 08-05-2009, 11:15 PM   #4
86.5 7MGE
86.5 7MGE's Avatar
Talking
Ok thanks I found a small pin hole spraying out from the hose going over the back side of the engine will be replacing it ASAP.
Cold Air Intake
NGK Wires and Plugs
Hi Flow CAT
MR Muffler
Super Coil
Evo Fog Lights
Evo Body Kit
Spark plug wires Quik Q carfanatic89 MKIII Supra 2 05-22-2008 01:46 PM
Broken spark plug! HELP! supraman121 MKIII Supra 2 10-02-2006 08:40 PM
spark plug wire WARNING! cars4me89 MKIII Supra 1 08-12-2006 06:24 AM
new mk3 owner, spark plug galley full of oil!???? katillidie MKIII Supra 6 03-24-2006 05:09 AM
spark plug wires kewlcoconut MKIII Supra 2 03-19-2006 07:45 AM
