Old 07-31-2009, 09:47 PM   #1
JZA70dood
JZA70dood's Avatar
JZA70dood is on a distinguished road
Question can i get some info on the center support bearing??
ok so my center support bearing on mydshaft is goin out..
no auto parts place can get this part for me and toyota of knox want $290 for it..
i was wondering what my options are besides spendin $290 for it..
is the csb diff on the nonturbo dshaft?
could i get a csb off of a gs300 or something and it work..?
i wanted to just have it welded into a 1 piece but the guys at the local driveline shop said no.. we wont touch a toyota..?
what are my options?
thnx
JZA70dood is offline   Reply With Quote
Old 08-01-2009, 08:40 PM   #2
gmansupra
gmansupra's Avatar
gmansupra is on a distinguished road
Default i'm not the only one
what i ended up doing was getting one from o'rielys . you have to put the new bearing in the old housing but if you can weld or know someone who can you only spend about 100 bucks. Hope this helps!
1985 project 1988 w/1jzte/afic/3" stainless exh
gmansupra is offline   Reply With Quote
Old 08-01-2009, 11:46 PM   #3
JZA70dood
JZA70dood's Avatar
Question
well i just drove to asheville nc to get a whole dshaft used and the csb (was good)..
yeah right..
just wasted 4hrs to get there and back and the money i bought it for and the time at the shop puttin it on..
its gettin very frustrating..
dnt get me wrong i love the car and the power it has to offer but this dshaft stuff is really gettin to me..
it would be a diff story if i could just get the part i need and be done..
but no.. it doesnt work out that way..
but yeah thnx for the reply but all the local shops here say no can do..
discontinued item..
can any one else help??
Old 08-02-2009, 05:36 PM   #4
Busted Knuckles
Busted Knuckles's Avatar
Default I'm surprised!
I'm surprised a driveline shop would refuse work. I've seen places on the web that offer 1-piece drive shafts for Supras, but cannot seem to find them right now. I have an original driveshaft out of a parts car I purchased last year as a spare for my original. One idea was to take it to a driveline shop here in Atlanta to have it converted to a 1-piece. Basically take the two joints at the end, and have a new shaft welded in-between. I guess now I have to check to see if I can find a place to do it.
Old 08-02-2009, 06:20 PM   #5
JZA70dood
JZA70dood's Avatar
id deff look into it if i were u..
if they do it then it would be much cheaper than buying a aftermarket..
im just gonna keep lookin..
maybe ill luck upp and find a shop that will do it or mind a dshaft at a ok price..
1jzgte bby >>
r154 tranny >>
tein adjustables >>
borla stainless 3" exhaust >>
skunk2 muffler w/ 4"outlet >>
17" staggerd sport max wheels >>
trust >>
momo >>
and some >>
Old 08-02-2009, 08:45 PM   #6
gmansupra
gmansupra's Avatar
Default it is so easy
yea it is to bad no one will do it because it only takes about twenty mins. drill out 4 spot welds,spread it open replace the bearing/isolator assy then push it back together. if you keep the housing square the mount bolt will take care of welding it back together. the part # is 8588 for the new one.no vibrations after but that was w/my 7m dont know about the 1jz yet
Old 08-03-2009, 04:01 PM   #7
JZA70dood
JZA70dood's Avatar
well i found a used dshaft on ebay and they say all bearings are good so..
yep..
i guess ill be buying it..
and it better be good.
1jzgte bby >>
r154 tranny >>
tein adjustables >>
trust >>
momo >>
and some >>
Car Show To Raise Funds For Autism Center khooper Off Topic Forum 0 04-19-2008 05:20 AM
drive shaft hanger bearing Robes88 Non-Generation Specific Questions 4 10-15-2006 03:49 AM
Center Support Bearing Problem purplescott MKIII Supra 0 03-27-2006 10:17 PM
do luck middle support bar?? stiffin er up joel w MKIII Supra 1 11-09-2005 03:07 PM
