Old 08-10-2009, 04:48 AM   #1
scaggsj
scaggsj's Avatar
Default Injectors
I was cleaning my fuel rail and the injectors and was wondering if there is a lube that is supposed to go on the orings of the injectors?
Old 08-10-2009, 05:57 AM   #2
Kevin
not that i know of.. as long as everything is cleaned out good you should be ok.
so you have your new gasket in yet?
Old 08-10-2009, 04:17 PM   #3
scaggsj
scaggsj's Avatar
No not yet head wont be back until wed. Gasket kit wont be here till tues right now im just cleaning everything and dreaming about it being on the road I really cant wait to get this back on the road.
Old 08-11-2009, 01:45 AM   #4
Kevin
its gonna be a long and painful process getting the ride back on the road haha. i kept running into problems and my car still isnt on the road
Old 08-11-2009, 03:18 AM   #5
scaggsj
scaggsj's Avatar
So far its been really smooth sailing, no problems I got the head off today and it was blown on on cyl 1 and cyl 6. small blow but enough. You definitly hear if I do run into any problems as Ill be posting whats wrong with your ride?
Old 08-11-2009, 03:23 AM   #6
Kevin
right now it wont idle on its own...when i start it.. it starts up. then dies unless i give it gas. it will idle on its own when i adjust the idle screw.. but when i do that.. idling starts loping. i'm gonna replace the iacv and see what happens. there seems to be a misfire.. not 100% sure though.. and i gotta replace a knock sensor (getting code 52)... im sure i have the timing dead on.
before it wouldnt drive past 3000rpm (it was in safe mode because i had a huge intake and boost leak)
heres some vids
http://www.youtube.com/watch?v=Nho0QrUcvek
Old 08-11-2009, 03:27 AM   #7
scaggsj
scaggsj's Avatar
have you tested the idle air control valve with a multimeter?
Replacing the headgasket burton51m Show n Tell 4 07-12-2010 04:47 AM
copper gasket sealer on fel-pro headgasket? skadaloz MKIII Supra 0 04-10-2009 12:04 AM
a few questions about the mkIV supra :D:D bad.boy MKIV Supra 4 09-17-2008 01:27 PM
Need your gus help- a few questions ravenmaster MKIII Supra 10 10-21-2006 09:59 PM
new here, few questions SoooopRa! MKIII Supra 6 08-29-2006 11:25 AM
