#21 |
my bad guys, been on supramania for too long. it's a hostile environment there... the only thing that i will not apologize for is when people dont use the search button... is your engine pinging since the knock sensor code?
#22 | |
![]() Quote:
probably not because with the code.. the ecu compensates and retards timing. i had the code when i broke my ks connector. no spark knock... |
#23 |
Hi guys,
I am new here so greetings to all!!!!!!!! ![]() I need some info on coolant and intake air temp sensor values in volts cold and hot. My engine is a 2JZGTE twin turbo 3 liter. Godspeed...... ![]() |
#24 |
#25 |
Hi Kevin,
The voltage values from the coolant and intake temp sensors that returns to the ecu !!!!! When cold the values on a Nissan is 3.25 volts and hot 1.25 volts for the coolant sensor. Do you know if these are the same for the 2JZGTE engine ?? ![]() Grt.... |
#26 |
ok hey guys sorry for taking so long to get back to u on checking the tps. but i just did it just now and i am confused as shit... lol. i tried doing it the way the tsrm shows but its just too confusing for me? everything seems within spec. so i go to the page to adjust it. so i can adjust it. and it says insert .7mm thickness gauge so i did that.. then i check out idl and e2 with an ohm meter.. i get about 20 ohms then i rotate clockwise.. im supposed to rotate until it "DEFLECTS" ... what the hell does that mean? when i rotate it it read "0.L"... does that mean it deflected? lol. well i gotta put my car back together cuz i need to drive it. any advice would help. this is too confusing. and also my thickness gauge only goes up to .88mm and i need .9mm lol will that be a problem?
#27 |
Super Moderator
Deflection would be if the value changes or jumps. This is usually easier to see on an analog meter, but if you're going slow enough you should be able to see it on a digital one as well. However, that step is to be done if you need to change the setting. Before you adjust it, you need to check the position of it using those feeler gauges at the top of the page I linked to earlier in this thread. If it's not in spec, then you need to turn it and watch for deflection.
1989 7MGTE R154 Targa Top White Package w/Blue Interior Driftmotion 57trim CT26, Upgraded Intercooler, 2.25" Hard Pipes, 3" Turbo Back Exhaust with Test Pipe, HKS VPC w/GM 3 bar MAP sensor, APEXi S-AFC, Walbro 255lph fuel pump, ProSport EVO Series Boost / Fuel Pressure / AFR gauges, Lotek a Pillar Gauge Pod, HKS Type 0 Turbo Timer, Eibach Lowering Springs, Tokico Illumina II TEMS struts, custom powder coated Motegi Racing TrakLite wheels |
#28 |
ok so whatever i did... made it worse!! LOL shit.
This is a vid of it cold http://www.youtube.com/watch?v=5bXwHcuHS5k (btw i am not touching the gas or anything) this is a vid of it warm http://www.youtube.com/watch?v=NNzXQvtmczM (every once in a while it does that wierd thing in the first video even when it is warm) do you think i have a bad tps? cuz i do have a code 51 aswell as a code 52 (i gotta rewire my KS's) or should i try adjusting the tps again? im using a digital meter so its pretty damn hard to keep it all steady and touch the right leads to look for "deflection" <---- would the number changing to "0.L" from an actual number mean deflection? this is just too confusing for me! sorry Last edited by Kevin; 09-02-2009 at 04:19 AM. |
#29 |
Super Moderator
Well, deflection should be any change in the resistance. A jump from an actual number to "0.L" (which I'm assuming is the infinite reading for your meter) would be a deflection in the reading.
So I have a question for you; after you adjust the TPS, do you take the 4 readings (as well as the 5th check where you make sure that between the VC-E2 terminals the resistance is between 4.25-8.25 kilo-ohms at all throttle positions) again? If not, then you might actually be putting it farther off of it's mark. If you can't get it within spec, you might need to replace the TPS.
#30 | |
![]() Quote:
i'll try again when i have some time. |
Thread Tools | |
Display Modes | |
idle problems | 88 supra turbo | MKIII Supra | 14 | 03-13-2010 03:43 AM |
won't idle | 3.0trd | MKIII Supra | 6 | 06-15-2009 07:23 PM |
Wastegate Idle issue... please help | Subjug4tor | MKIII Supra | 9 | 05-15-2008 01:59 AM |
Car doesnt like to idle in the morning | XxSupra4LifexX | MKIII Supra | 11 | 12-24-2007 07:27 AM |
HELP!!!! '87 Supra idle problem | Morpho | MKIII Supra | 0 | 10-03-2005 02:40 PM |
