Old 08-13-2009, 08:20 PM   #1
Kevin
Default Car wont idle (wont stay on)
So basically after my hg.. my car will start and run.. but wont stay on (wont idle).. it just dies. when i start it up.. it just hits 1000rpm and then slowly dies. i thought it was the iacv.. so i changed it... and nothing was different. the car will stay on if i hold on the gas.. or if i really adjust the idle screw on the throttle body but i was told that that shouldnt be adjust and that the idling is controlled my the iacv. when i do ajdust the crew though the car starts loping idle.. which is understandable. so basically i'm stumped. i'm open for suggestions. btw when i hold the rpms at around 700-1000 .. the car is really rough and above 2000 rpm it is smooth but there seems to be the occasional misfire/backfire sound. i changed the plugs and wires already.
Old 08-14-2009, 03:24 PM   #2
Kevin
videos of it..
this video i am not touching the gas
http://www.youtube.com/watch?v=04J68xPIsas
btw i had to have the air bypass screw almost all the way out for the car to actually stay on when it wasnt warmed up yet.
the car slows down like this and dies if it isnt warmed up.
http://www.youtube.com/watch?v=n5_yo...eature=channel
this is how it sounds
http://www.youtube.com/watch?v=2RrhM...eature=channel
Old 08-14-2009, 03:38 PM   #3
corrosivecopper
corrosivecopper is on a distinguished road
It's hard to tell in the video, but it seems ya may have a vac leak somewhere. Have ya double checked all your lines and made sure they're where they should be? As well double check the torque on your EGR valve.. I forgot to tighten the bolts on the one to the intake and it idled really rough and wouldn't stay running until I realized it and tightened it. Was fine after that except the loud knock.. different issue though lol
corrosivecopper is offline   Reply With Quote
Old 08-14-2009, 03:55 PM   #4
Kevin
yup checked vacuum line 5+ times lol as i had this probles for about 3 weeks. i'll double check the egr torque. i'm sure i tightened them though
Old 08-14-2009, 08:31 PM   #5
mirage83
Might want to check your AFM. If you've gone through all the vacuum lines (and there are a BUNCH of them, some tucked away and hiding), check your AFM connections and the I/C piping for problems.
Old 08-15-2009, 02:27 AM   #6
Kevin
yup check afm and ic piping already .. probably one of the first things i did because i thought the problem was afm related.. but it isnt. there arent anycodes other then 52.. which is my KS.. which i fix already.. i just need to rewire the front one. but a KS shouldnt cause this problem though..
the next thing i might look at is the tps.. after that.. im stumped
Old 08-17-2009, 03:59 PM   #7
Kevin
bump any other suggestions?
Old 08-17-2009, 08:18 PM   #8
btwilson86
Super Moderator
btwilson86's Avatar
Have you checked that tps yet? How far off was it, or was it dialed in correctly?
Old 08-18-2009, 01:41 AM   #9
Kevin
not yet. I need to go get some new feeler gauges when i have some free time this week. i am assuming i just adjust it following the tsrm?
Old 08-18-2009, 03:01 AM   #10
btwilson86
Super Moderator
btwilson86's Avatar
Yup. It's probably one of the easier things to do on these cars... Just have to check resistance 4 times, and if it's not in spec loosen the screw and rotate until it is.
idle problems 88 supra turbo MKIII Supra 14 03-13-2010 03:43 AM
won't idle 3.0trd MKIII Supra 6 06-15-2009 07:23 PM
Wastegate Idle issue... please help Subjug4tor MKIII Supra 9 05-15-2008 01:59 AM
Car doesnt like to idle in the morning XxSupra4LifexX MKIII Supra 11 12-24-2007 07:27 AM
HELP!!!! '87 Supra idle problem Morpho MKIII Supra 0 10-03-2005 02:40 PM
