I have an '89 Supra (7MGE) with 133K miles. It runs great, but I decided it was time to change the spark plugs. I also wanted to do a compression check before installing the new plugs. The service manual indicates a desired compression value of 156 psi or more, a minimum desired value of 128 psi, and no more than 14 psi difference among cylinders. The average values I obtained ranged from 207 to 217 psi. I did not expect to see values this great and now I am wondering if my compression guage is not properly calibrated. Insight anyone ??
#2 | |
![]() Quote:
1) Faulty readings 2) Carbon build up on the pistons and/or head 3) Someone put in high compression pistons 4) The head/block was/were milled enough so that it would change the compression 5) A thinner head gasket was used than stock specs
_____|_____ /. . . \ . . . \ . .\ ( ]/ . . . . \ . . . \ . .\[ ) _________________ /OO]====(W)====[OO\ [___________________] [ [O] ///______\\\ [O]_] ____________________[||]______________[||]____________________ |
Thanks for the insights Tony.
I can rule out reasons 3, 4, and 5: I have owned this car since the day I drove it off the showroom floor and have made no such modifications. Some time ago I read something about de-carbonizing an engine. Do you think this is something I should consider doing? Is there anything harmful about running an engine with these high compression values (assuming the readings are not faulty) ? |
I have only "de-carbonized" pistons once, but the engine was fully disassembled...and that is the extent of my experience with that.
As far as continuing to drive a car with that much compression (like you said IF true), pinging/detonation/pre-ignition would be your biggest concern. Do you hear pining when going uphills? Do your spark plugs look like what illustrations show for pinging? Sometimes plugs can be a clue, but your ears should pick up on it. Engineers want a car to be as high compression as possible without pinging problems. Higher compression engines are more fuel efficient and more powerful (all else being equal).
She seems to run fine; no "pinging" even under engine strain such as pulling a hill in 5th gear. At this point I think I will recheck compression with another guage (if I can get one) then get her back on the road ...
#6 |
Those are pretty high but the important thing is that they are all pretty close to each other. How many cranks did you do? I do three revolutions then check. Are you doing it wet or dry? The wet test numbers are higher than the dry test numbers.
Maintenance brake and clutch master cylinder fluid | IHateHacks | MKIII Supra | 1 | 04-18-2007 07:15 PM |
# 5 cylinder DEAD!??? | Caliturbo88 | Non-Generation Specific Questions | 4 | 01-31-2007 03:49 AM |
Compression and Block Tests | mrnickleye | Supra FAQ | 0 | 01-29-2007 03:49 AM |
looking at a 90 turbo with compression problems | jtitzer56 | MKIII Supra | 1 | 09-23-2006 05:27 PM |
Compression Question | Intenseneal | MKIII Supra | 5 | 08-15-2005 10:27 AM |
