Old 08-19-2009, 12:58 AM   #1
hillbillytuner
hillbillytuner is on a distinguished road
Default need help
ok what vac lines can i take off and still run i just want it to look cleaner in the bay
hillbillytuner is offline   Reply With Quote
Old 08-19-2009, 02:21 AM   #2
mirage83
Well lets see. The ones to the power steering pump are about the only ones that aren't necessary/needed, but pulling them will prevent the engine from reving slightly when the wheels are cranked over at low rpms. Just about everything else vacuum hose-wise is used in emission or engine controls. Pull them and you'll have all sorts of issues. Not fun.
You'll have better luck doing a wire move and tuck.
