Old 08-22-2009, 01:58 PM   #1
Dan Swanson
Dan Swanson is on a distinguished road
Default Throttle Position Sensor
While working on my N/A 1987 Supra MKIII. The connector to TPS feel apart. I hope some one will be able to tell which wires go the correct pins on the TPS. With this info I can make it work.
However, if there is any where I can buy an OEM connector? that is the best solution.
This car is for sale once I get it runninng. Thank you for any assistance / advice you can provide.
Dan Swanson
danwswanson@hotmail.com
407.671.8310
Central Florida
Dan Swanson is offline   Reply With Quote
Cam Position Sensor JMoses MKIII Supra 4 08-19-2009 05:09 PM
Idle Position Sensor Problem White87Turbo MKIII Supra 4 06-20-2006 05:38 AM
Cam position sensor and Knock sensor Burn N' Up MKIII Supra 1 11-23-2005 11:27 PM
throttle position sensor 88turbo1 MKIII Supra 6 09-24-2005 04:51 PM
SUB THROTTLE POSITION SENSOR BYPASS TRICIA93TT MKIV Supra 0 08-26-2005 03:31 AM
