While working on my N/A 1987 Supra MKIII. The connector to TPS feel apart. I hope some one will be able to tell which wires go the correct pins on the TPS. With this info I can make it work.
However, if there is any where I can buy an OEM connector? that is the best solution. This car is for sale once I get it runninng. Thank you for any assistance / advice you can provide. Dan Swanson danwswanson@hotmail.com 407.671.8310 Central Florida |
Cam Position Sensor | JMoses | MKIII Supra | 4 | 08-19-2009 05:09 PM |
Idle Position Sensor Problem | White87Turbo | MKIII Supra | 4 | 06-20-2006 05:38 AM |
Cam position sensor and Knock sensor | Burn N' Up | MKIII Supra | 1 | 11-23-2005 11:27 PM |
throttle position sensor | 88turbo1 | MKIII Supra | 6 | 09-24-2005 04:51 PM |
SUB THROTTLE POSITION SENSOR BYPASS | TRICIA93TT | MKIV Supra | 0 | 08-26-2005 03:31 AM |
