Old 08-24-2009, 11:22 PM   #1
OsiowyMK3
OsiowyMK3 is on a distinguished road
Default Multiple Questions
1. Can you use the W-58 Transmission with a 7m-gte as a daily driver?
2. Does every MK3 rust under the spare tire a lot?
3. What are some causes for fog lights not coming on? (brand new lights)
4. Will the N/A Gauges work with a turbo engine? Can I swap the gauges from a turbo car to the N/A?
5. Will the N/A Exhaust some how mount to the engine? Or should I take the exhaust of a turbo model?
6. What are a few reasons the Emergency brake is not grabbing?
OsiowyMK3 is offline   Reply With Quote
Old 08-25-2009, 12:07 AM   #2
kwnate
1. yes, upgrade the clutch.
2. no, only ones with worn seals
3. fuse, bad switch, f'd wiring.
4. tach won't without modding, speedo may be off.
5. it could, but i wouldn't recommend it.
6. broken/stretched cables, busted shoes.
Nate
Old 08-25-2009, 01:11 AM   #3
OsiowyMK3
Thanks very much. And how do you mean modding the gauges? None of them will work?
Purchasing and upgrade questions for a 1993-1996 supra non turbo slayer8925 MKIV Supra 9 04-29-2009 09:31 PM
Questions before buying a Supra proximityburn MKIV Supra 5 08-15-2008 02:09 AM
Some questions about my 1988 Supra... Somajunkie Non-Generation Specific Questions 11 06-18-2007 05:47 AM
newbie questions erik MKIII Supra 4 01-10-2006 11:37 AM
