#1 |
1. Can you use the W-58 Transmission with a 7m-gte as a daily driver?
2. Does every MK3 rust under the spare tire a lot? 3. What are some causes for fog lights not coming on? (brand new lights) 4. Will the N/A Gauges work with a turbo engine? Can I swap the gauges from a turbo car to the N/A? 5. Will the N/A Exhaust some how mount to the engine? Or should I take the exhaust of a turbo model? 6. What are a few reasons the Emergency brake is not grabbing? |
#2 |
SP58GT
1. yes, upgrade the clutch.
2. no, only ones with worn seals 3. fuse, bad switch, f'd wiring. 4. tach won't without modding, speedo may be off. 5. it could, but i wouldn't recommend it. 6. broken/stretched cables, busted shoes.
Nate ![]() ![]() |
#3 |
Thanks very much. And how do you mean modding the gauges? None of them will work?
Thread Tools | |
Display Modes | |
Purchasing and upgrade questions for a 1993-1996 supra non turbo | slayer8925 | MKIV Supra | 9 | 04-29-2009 09:31 PM |
Questions before buying a Supra | proximityburn | MKIV Supra | 5 | 08-15-2008 02:09 AM |
Some questions about my 1988 Supra... | Somajunkie | Non-Generation Specific Questions | 11 | 06-18-2007 05:47 AM |
Need your gus help- a few questions | ravenmaster | MKIII Supra | 10 | 10-21-2006 09:59 PM |
newbie questions | erik | MKIII Supra | 4 | 01-10-2006 11:37 AM |
