Old 08-20-2009, 11:37 PM   #1
scaggsj
scaggsj's Avatar
Default Fuel rail constanlty running
I got my 7MGE back together after a blown head gasket repair, it starts but timings off. The problem is that when I turn the key to the on postion the fuel pump kicks on and then theres a sounrd under the hood like injectors or rail is just running I know that the rail dosent actually run but thats where the sound is most previalent. Any Ideas? Like I said everything seems fine just a noise.
1987 Supra 7MGE - Auto - Stock - White
Previoius Toyotas;
1992 Toyota Celica Gt, (Sold)
1988 Toyota Celica Alltrac Turbo (Died)
Old 08-23-2009, 04:35 AM   #2
scaggsj
scaggsj's Avatar
Im going to try and run a fuel pressure test this week some time after I get the timing set, its being ridiculious Ill get the marks all lined up then after a couple revolutions itll be off again then the distributer isnt lineing up right or something cause I line up the groove on it and the indented circle and the car one run but if I move back a couple teeth itll run just really poorly. I plan to take it to someone who can set timing better than me. Ill let you guys know what I find out about the fuel thing.
Previoius Toyotas;
Old 08-25-2009, 02:33 AM   #3
scaggsj
scaggsj's Avatar
Turns out if the air flow meter reads any air then fuel pump will continue to run unpluged it and noise stops. I must have messed something up when i unplugged it. Just posting incase anyone else has same problem.
Previoius Toyotas;
Old 08-26-2009, 04:07 PM   #4
Toyota Fan
Toyota Fan is on a distinguished road
Default funny
I had the same problem with mine when I bought it took me a bit of trouble shooting but easy fix
Toyota Fan is offline   Reply With Quote
Old 08-27-2009, 03:01 AM   #5
scaggsj
scaggsj's Avatar
did you just replace it? I think when I pulled it apart something happened cause before bhg it ran fine. The unit is sealed it seems and a new one cost like 230.00
Previoius Toyotas;
fuel rail G-string MKIII Supra 6 02-15-2011 02:40 AM
Lipp Fuel Rail Problem sprigmo1 MKIII Supra 3 02-26-2009 06:03 AM
Testing for bad ECU, &/or bad Fuel Pump elliotl MKIII Supra 0 08-21-2007 10:42 PM
fuel running very rich famous Non-Generation Specific Questions 8 08-17-2006 01:49 PM
