Old 09-30-2009, 10:44 AM   #11
ddmcse
ddmcse's Avatar
Cool
when dealing with a possible BHG on a supra don't use Napa parts . you might save 7 dollars but you've got no piece of mind now.
wouldn't you feel better knowing it was a yota thermostat ?
300+ RW HP Dyno run,
Blown HeadGasket info
My Supra KiXGaS
Old 09-30-2009, 05:49 PM   #12
Bill UK
AEM EMS
Bill UK's Avatar
Originally Posted by RNEMESiS42 View Post
The bolts for the thermostat housing were rusted, and BOTH of them broke at the head when I was using a socket to get them out. This left the rest of the bolts stuck on the part that's attached to the engine.
Use this website when searching for parts Link The water outlet housing part # is 16333-42040 price 35.72 Euro`s Gasket 16343-42020 at 2.0 Euro`s The studs are not listed, I think they are 6.0mm. You should be able to remove the broken studs with a stud extractor (easer said than done) or ask a machine shop to remove them, a lot cheaper than buying a new housing.
Blown Head Gasket Symptoms! Dejvid1785 MKIII FAQ 76 04-24-2011 07:59 PM
86.5 and 87 symptoms sd88supra MKIII Supra 8 12-05-2007 08:56 AM
88 turbo, Any idea on what causes these symptoms? christutecky MKIII Supra 0 02-02-2007 07:19 PM
Strange syptoms rob Johnson MKII Supra 9 10-28-2005 03:16 PM
NEW OWNER! (whatre the symptoms of a...) 91SupraTURBO MKIII Supra 11 07-13-2005 12:03 PM
