Old 08-26-2009, 04:52 AM   #1
RNEMESiS42
RNEMESiS42's Avatar
RNEMESiS42 is on a distinguished road
Default BHG symptoms...but no BHG?
My birdcage light has been coming on and off every once and a while ever since I bought my car four years ago. Around last April I was driving my car when all of a sudden I saw steam coming up from the hood. I pull over and see that my radiator overflow tank is filling up. The temperature gauge in my car looked normal. I drove home and parked my car indefinitely, fearing a blown head gasket. I haven't driven my car since then and recently decided to test it for a BHG. I purchased the $45 block test kit form NAPA, and tried it out. I did it twice, and got negative results for exhaust gases in the coolant. Afterward I drove it about a half mile and back, and noticed when I parked that the same issue is occurring: coolant spilling out into the overflow tank.
What could be wrong? Thermostat or radiator busted? I have no other signs that would relate to a BHG.
White 1987 N/A. Automatic. Targa top. TEMS
RNEMESiS42 is offline   Reply With Quote
Old 08-26-2009, 07:20 AM   #2
btwilson86
Super Moderator
btwilson86's Avatar
Have you ever messed with the line going in and the line going out of the cap on your overflow? If so, you might have them backwards....
Basically what would happen is this: as your car heats up, pressure forces coolant into overflow through the tube that feeds to the bottom of the reservoir. As the car cools down, it'll suck the coolant back into the cooling system via that same hose.
If the lines are backwards, as the coolant expands it'll fill up the reservoir as it normally should. The problem is, it can't drink it back up cuz the line running from the radiator is not hooked up to that little hose that goes to the bottom of the reservoir. So the coolant will just sit in there.
Next time you drive the car, more coolant will try to go into the reservoir. Once it's full it's gonna go straight out that other line on the overflow cap, which is the purge line that goes straight to the ground, thus making it seem like an over-pressurized cooling system (like with a blown head gasket) when in reality it's just 2 hoses hooked up backwards.
That was alot longer than I thought it'll be, sorry for the ramble
Old 08-26-2009, 07:30 AM   #3
RNEMESiS42
RNEMESiS42's Avatar
Thanks for the response, I'll check it out in the morning. I've never directly messed with my overflow tank, but it sure would be nice if it's as simple as this.
Old 08-26-2009, 05:56 PM   #4
RNEMESiS42
RNEMESiS42's Avatar
There's just the one line from the top of my radiator to the cap of the overflow. It all looks fine to me.
Old 08-26-2009, 08:12 PM   #5
Bill UK
AEM EMS
Bill UK's Avatar
1. Thermostat not opening. (stuck closed)
2. Water pump impellor vanes corrode.
3. Blocked rad
4. Viscous fan coupling slipping
5. Also check this out Link
Old 08-28-2009, 02:00 AM   #6
oregonjoe
oregonjoe's Avatar
Default If it smells like a BHG
I too had the same problems, blowing coolant out reservoir, no hot temp on gauge, negative test for exhaust gas – but in the end, it still was a BHG, The best test for BHG in No 6 cylinder is to look at spark plug – you will see a difference in the plug for the BHG cylinder compared to the rest (looks like the coolant color). The EG test does not find minor leaks when the compression is high.
Looks at the plugs and if it looks like a BHG, Runs like a BHG and smells like a BHG – then it probably is!
I had to pull and rebuild my engine as a result.
Old 08-28-2009, 06:40 PM   #7
RNEMESiS42
RNEMESiS42's Avatar
Damn, I'll look at the plugs, then. A few of those plugs are so annoying to get at, though!
Old 09-29-2009, 10:19 PM   #8
RNEMESiS42
RNEMESiS42's Avatar
SO, I thought the easiest and cheapest thing to do would be to replace the thermostat for starters. I picked one up form NAPA and proceeded to replace it. The bolts for the thermostat housing were rusted, and BOTH of them broke at the head when I was using a socket to get them out. This left the rest of the bolts stuck on the part that's attached to the engine.
Does anyone know the part number for this so I can replace it? All I can find is the thermostat housing (number 8 in the picture below), not the piece that it attaches to.
Old 09-29-2009, 11:09 PM   #9
2jzmaestro
2jzmaestro is on a distinguished road
good thing you asked.
i bought parts for my 2jz at http://toyotapartszone.com
they have something called "hot spots" on their digram
gives you all the parts name and number
its a really helpful website and cheap parts
hope this helps
2jzmaestro is offline   Reply With Quote
Old 09-29-2009, 11:11 PM   #10
RNEMESiS42
RNEMESiS42's Avatar
Phew...I just found the part number in this thread:
I'm going to to buy that sucker and the gasket, and be on my way...this has been l the fun replacement of a thermostat ever.
Blown Head Gasket Symptoms! Dejvid1785 MKIII FAQ 76 04-24-2011 07:59 PM
86.5 and 87 symptoms sd88supra MKIII Supra 8 12-05-2007 08:56 AM
88 turbo, Any idea on what causes these symptoms? christutecky MKIII Supra 0 02-02-2007 07:19 PM
Strange syptoms rob Johnson MKII Supra 9 10-28-2005 03:16 PM
NEW OWNER! (whatre the symptoms of a...) 91SupraTURBO MKIII Supra 11 07-13-2005 12:03 PM
