Old 08-26-2009, 10:48 PM   #1
venomstreetmachine
Banned
venomstreetmachine is on a distinguished road
Question Mk3 not boosting ! Help....
Hi guys, I got this sweet Mk3 with all kinds of mods.
i just built this engine with stage 2 internals.
Got a super T4 turbo with 3' V band and an external Tial wastegate.
I also have a Turbo XS T4 manifold.
I have everything hooked up but I am not getting any boost.
The turbo has no shaft play, spins freely by hand ( its brand new)
I start the car and when I rev up I should hear the turbo or see some boost but I dont. I checked all intercooler pipes and vacuum lines,,, checked OK
I reved it up to 5K RPM and let off the gas, my HKS BOV should have gone woosh ! My boost gauge shows -10 and when i gas it, it goes to 0.
Does anyone have any ideas? Perhaps anyone have Vacuum diagrams on the 7MGTE?
Also, what symptoms would occur if the knock sensor is not hooked up and the O2 sensor not plugged in?
venomstreetmachine is offline   Reply With Quote
Old 09-24-2009, 06:53 AM   #2
Sp00nzZ
Sp00nzZ is on a distinguished road
Yeah, i've encountered the same problem. No boost while sitting still, but boosts fine when im driving.
Dunno, sounds like it may be either a common problem or on purpose from the manufacturer.
^^ dunno, i'd like to know though.
Sp00nzZ is offline   Reply With Quote
Old 09-24-2009, 11:32 PM   #3
DarkSupra2.5
DarkSupra2.5's Avatar
DarkSupra2.5 is on a distinguished road
Uh guys, you should only get boost under load, as in, only when driving. If you're getting boost while just sitting there, that's kind of a problem.
1jz-gte swap (Currently spun #3 rod bearings), Apexi high flow filter, Greddy thrust 3" downpipe, N1 3" catback with cat delete tube, 1 peice driveshaft, Bar and Plate intercooler, and 440 JDM 2jz injectors.
Possible 2jz lower block swap in the works if I can't rebuild the 1j. So troublesome.
DarkSupra2.5 is offline   Reply With Quote
Old 09-25-2009, 01:06 PM   #4
kwnate
SP58GT
^^ Exactly, drive the car. If you still see no boost then you have a problem. And what exactly are stage 2 internals? Are we playing gt2?
Nate
Old 09-28-2009, 08:34 PM   #5
ddmcse
ddmcse's Avatar
Cool
gt2 lol . there should be a sticker with the hose diagram stuck under the hood
300+ RW HP Dyno run,
Blown HeadGasket info
My Supra KiXGaS
Old 11-12-2009, 01:32 AM   #6
SupraJosh
SupraJosh is on a distinguished road
Default mk3 not boosting
my mk3 was boosting just fine one day and all of a suddon it just stopped boosting, i have not figured out what it is yet... i have checked the intercooler piping and vacume lines....not boosting at all.
SupraJosh is offline   Reply With Quote
Old 11-12-2009, 06:55 AM   #7
Check the wastegate... the gate or the actuator could be stuck.
EDIT: didn't see it's an external WG, still should be checked.
Tags
boost, exhaust, mk3, turbo, vacum
Boosting my 88 7mge lemonhead4696 Non-Generation Specific Questions 5 07-02-2008 02:24 AM
Boosting a 7MGE or swapping it out. Knightryder MKIII Supra 12 08-16-2007 04:45 PM
Safe boosting for na-t supraman121 MKIII Supra 0 01-06-2007 08:13 PM
Boosting Up My Stock Turbo TRD 7M~GTE MKIII Supra 2 02-23-2006 08:30 PM
boosting turbo steve119md MKIII Supra 2 09-15-2005 11:09 AM
