Banned
Hi guys, I got this sweet Mk3 with all kinds of mods.
i just built this engine with stage 2 internals. Got a super T4 turbo with 3' V band and an external Tial wastegate. I also have a Turbo XS T4 manifold. I have everything hooked up but I am not getting any boost. The turbo has no shaft play, spins freely by hand ( its brand new) I start the car and when I rev up I should hear the turbo or see some boost but I dont. I checked all intercooler pipes and vacuum lines,,, checked OK I reved it up to 5K RPM and let off the gas, my HKS BOV should have gone woosh ! My boost gauge shows -10 and when i gas it, it goes to 0. Does anyone have any ideas? Perhaps anyone have Vacuum diagrams on the 7MGTE? Also, what symptoms would occur if the knock sensor is not hooked up and the O2 sensor not plugged in? ![]() ![]() |
Yeah, i've encountered the same problem. No boost while sitting still, but boosts fine when im driving.
Dunno, sounds like it may be either a common problem or on purpose from the manufacturer. ^^ dunno, i'd like to know though. |
Uh guys, you should only get boost under load, as in, only when driving. If you're getting boost while just sitting there, that's kind of a problem.
1jz-gte swap (Currently spun #3 rod bearings), Apexi high flow filter, Greddy thrust 3" downpipe, N1 3" catback with cat delete tube, 1 peice driveshaft, Bar and Plate intercooler, and 440 JDM 2jz injectors. Possible 2jz lower block swap in the works if I can't rebuild the 1j. So troublesome. |
^^ Exactly, drive the car. If you still see no boost then you have a problem. And what exactly are stage 2 internals? Are we playing gt2?
Nate ![]() ![]() |
gt2 lol . there should be a sticker with the hose diagram stuck under the hood
#6 |
my mk3 was boosting just fine one day and all of a suddon it just stopped boosting, i have not figured out what it is yet... i have checked the intercooler piping and vacume lines....not boosting at all.
#7 |
Check the wastegate... the gate or the actuator could be stuck.
EDIT: didn't see it's an external WG, still should be checked. |
Tags |
boost, exhaust, mk3, turbo, vacum |
Boosting my 88 7mge | lemonhead4696 | Non-Generation Specific Questions | 5 | 07-02-2008 02:24 AM |
Boosting a 7MGE or swapping it out. | Knightryder | MKIII Supra | 12 | 08-16-2007 04:45 PM |
Safe boosting for na-t | supraman121 | MKIII Supra | 0 | 01-06-2007 08:13 PM |
Boosting Up My Stock Turbo | TRD 7M~GTE | MKIII Supra | 2 | 02-23-2006 08:30 PM |
boosting turbo | steve119md | MKIII Supra | 2 | 09-15-2005 11:09 AM |
