#21 |
Super Moderator
Most of the speedo cable is 1 long piece from the gauges down near the tranny. The second piece is only about 6-7 inches long, I believe it's got a slight curve in it. The last piece is a short, somewhat curly piece (often called a "pig tail") that connects to the transmission.
1989 7MGTE R154 Targa Top White Package w/Blue Interior Driftmotion 57trim CT26, Upgraded Intercooler, 2.25" Hard Pipes, 3" Turbo Back Exhaust with Test Pipe, HKS VPC w/GM 3 bar MAP sensor, APEXi S-AFC, Walbro 255lph fuel pump, ProSport EVO Series Boost / Fuel Pressure / AFR gauges, Lotek a Pillar Gauge Pod, HKS Type 0 Turbo Timer, Eibach Lowering Springs, Tokico Illumina II TEMS struts, custom powder coated Motegi Racing TrakLite wheels |
#22 |
ok cool...thanks 4 that man, i will go have another look at it when i get the chance, i must have missed the link between the part coming out of the box and the short piece and just thought they were together lol
#23 |
Well hope you get it fixed, thats all i thought id have to do..now a new head gajet rebuild is up lol sadly i wont get to start on it for along time..grr
#24 |
I'm in the middle of a rebuild and I have to say taking the block out and having a shop shave the block and heads is the way to go. After years of slow leaking HG - it will eat away at the block surface making it very difficult to get it cleaned enough for another gasket to seal. The pitting and corrosion leaves defects that need to machined out.
Since the shop can do this with the block out, you can easily go to Metal HG and save the worry. Also, if it has been leaking awhile – you will want to do a bottom end rebuild just to get the new bearings and rings in. My crank and block checked out OK so it was $200 for the ring/bearing kit plus the $150 in shop costs to clean and shave the block and flywheel. I too have debated on stock or metal HG but the cost difference is $50 out of $1200 so if the block is out anyway – might as well do it right. The $1200 I’m into it now is $500 in shop costs and $700 in parts but it is a complete engine rebuild with new clutch |
#25 |
Complete rebuild as in new cams pistons and a crank? Cuz if you can do that for 1200 than im tempted to do so myself.
#26 |
yer i think im up 4 a hg to, but im not 100% sure...if my radiator build up pressure after about 10sec of the motor runnin...does that mean the hg is blow and is sendin gas through the water mains???
oh and i also hav a new repair to do amung the rest of the speedo cable etc. lol....i broke an axle, so there is a day lost this weekend hahaha ...lucky i got a spare diff with the car when i bought it =P |
#27 |
The way i found out was after i drove it, didnt matter if if was for 2 mins or longer, i opened the hood and a lil bit of smoke was coming out of the motor. Than about 5ish minutes after i turned the car off, coolant flooded into the resivor and spilled over. If coolant fills the resivor and over flows, you have a bhg. If your exhaust is white too. You can check your oil too by drain a lil out and if its water your in trouble. And you can pop the cap on your radiator too(dont do it after driving or while running the car) and if oil is floatin on the top, you have bhg.
#28 |
ok... well i hav none of those symptoms...the oil isnt milky, there isnt any oil under the radiator cap, the water doesnt overflow from the resuvier (it happened once, but thats it)
as i said, it just builds up pressure in the radiator way to quick also the smoke ive got comin out is black (still tryin 2 figure out why it is running rich...) hmmmm...so the search continues hahaha |
#29 |
Running rich huh? Hows your air filter? Check your spark plugs to. And are you still getting decant boost?
#30 | |
![]() Quote:
The other key was checking all the tolerances with plasticgauge on the reassemble so I kew all the rod and crank surfaces were still perfect. Luckily the shop did not have take anything off to retrue the surfaces. A engine rebuild kit with pistons was $500 and crank would have been another $150. My pistons and crank were like new so I saved the money |
Thread Tools | |
Display Modes | |
Exhaust suggestions | cgreiner | MKIII Supra | 8 | 05-21-2009 08:04 AM |
No Power At All: Suggestions... | panblackrose | MKIII Supra | 8 | 05-17-2008 02:15 AM |
clutch suggestions | B3AN5 | MKII Supra | 0 | 10-21-2007 11:28 PM |
mod suggestions | edelmar417 | MKII Supra | 3 | 11-03-2006 02:26 AM |
Cheap Suggestions for a 1989 Supra N/A 5spd? | V1P3R | MKIII Supra | 7 | 03-07-2006 02:36 PM |
