Old 08-09-2005, 05:33 PM   #1
boostedmkIII
boostedmkIII is on a distinguished road
Hi everybody, Iam new to this site, but have had supras for the past 7 years. my current problem is on my 88 7mgte. The motor was built 3 years ago but the people that installed it broke 6 bolts on exhuast side of head. So for the cars first 12,000 miles the turbo was not operating correct. Now that problem has been fixed the car will only boost 4psi? I have done all sensor checks everything is ok, time set(10btdc). Iam getting a code 11 from diag/ ECU power sorce? any help would be great!!!!!! thanks
4" Turbo back/maft-pro powered/70mm TC turbo/JE Built forged motor
boostedmkIII is offline   Reply With Quote
Old 08-09-2005, 05:58 PM   #2
daiagaru2
daiagaru2 is on a distinguished road
if everything on the turbo side is hooked up correctly and works correctly then maybe the map sensor is failing,or the gauge is not opperating correctly.i hope i still have the book with trouble codes,hang out and lemme check.
daiagaru2 is offline   Reply With Quote
Old 08-09-2005, 09:47 PM   #3
boostedmkIII
every thing is hooked up, iam running a maf sensor off my other 91 supra turbo. You said my map sensor? I did not think they (supras) had map sensors? The turbo is the stock turbo with a diffrent comp/wheel, It sounds like it is moving way more air then stock. The guage may be wrong but I know it is not pulling as hard as it used to. It also seems like above 5500rpm boost psi stays at 4psi but does not pull hard like early in rpm range?
Old 08-09-2005, 10:40 PM   #4
ddmcse
ddmcse's Avatar
well they missed 11
but it says wire severance , however slight , in +B (ECU)
hers is how to check
test ecu
300+ RW HP Dyno run,
Blown HeadGasket info
My Supra KiXGaS
Old 08-10-2005, 12:14 AM   #5
Intenseneal
Guest
Posts: n/a
Are you still running the stock down pipe and cat. If yoy are then your cats might be clogged. Before I changed out my down pipe and cat with an after market test pipe and down pipe my car would not boost past 6 psi. After the parts were replaced my car peaks at 8psi ( 1 psi over stock). Start there if you have already replaced the cats then do a boost leak check, you might have a leaky I/C pipe/
Old 08-10-2005, 07:58 PM   #6
boostedmkIII
thanks for the help everybody, I pulled the ecu and tryed to do the check, first my connectors are diffrent then the picture, but the picture is the same as my 91 ecu. The check works on the 91 but like I said my 88 connectors are in a diffrent place in to the ecu. I looked at cygnus but they dont show any that 88 and 91 are not the same? They are diffrent which is why I cant just swap them.I am going to see if toyota can check for me, we'll see!
Old 08-10-2005, 08:57 PM   #7
boostedmkIII
ecu and relay work!!! my computer set up(88) IS SAME AS cygnus na 7mge
Old 08-15-2005, 11:17 AM   #8
suprra_girl
7M POWAH! ;)
suprra_girl's Avatar
http://www.supra.co.nz/tsrm.htm
87 tsrm
your ecu should be there
have you taken off the intake pipe to the turbo.. how does she look, any fins missing?
any play, in and out and side to side?
does it hold 4 psi or is it erratic
Pics of my build.
Do a diagnostic first!
Old 08-15-2005, 01:46 PM   #9
boostedmkIII
I hooked up a diffrent boost guage and have my 7 psi. My intake pipe was shot so I took the one off my 91 but it soon will need replaced to(cracks) not bad though. Thanks for the help everybody!
Old 08-15-2005, 01:49 PM   #10
suprra_girl
7M POWAH! ;)
replace that intake pipe quick!!!
i had one on my brand new 46trim ct26 and it was cracked
consequently i screwed my new turbo in 2 days coz the pipe let go and part of it went thru my turbo
glad you got it sorted tho
Pics of my build.
low boost psi, wtf supradad86_5 MKIII Supra 4 02-09-2014 02:05 AM
wont hold boost Supraman MKIII Supra 12 04-19-2007 04:52 AM
issue w/ boost spikes? i think? NOTORIOUS VR Non-Generation Specific Questions 17 01-17-2007 08:35 PM
installing manual boost controller 1989?? hamburgler MKIII Supra 4 07-13-2005 12:55 PM
No boost in neutral but boost in gear! edgardo MKIII Supra 5 10-09-2004 04:01 AM
