Old 09-06-2009, 01:41 AM   #1
ynnek
ynnek is on a distinguished road
Default Just bought 88 N/A
It needs a little TLC, but al in all it is a pretty nice find, $2200. 149k on the odometer. All original , bone stock. Automatic trans. the known problems are
  • Leaking power steering hose - pressure side
  • Carrier bearing shot
  • Dome lights not working
  • Power DL switch on driver door not working
  • Dent on driver side rear quarter panel
here are some pics.
ID:	2310   Click image for larger version
ID:	2311   Click image for larger version
ID:	2312   Click image for larger version
ID:	2313   Click image for larger version
ynnek is offline   Reply With Quote
Old 09-06-2009, 02:41 AM   #2
Igknyte
Igknyte's Avatar
Igknyte is on a distinguished road
welcome. my dome light doesnt work either... lol
White/Burg '89 MKIII Targa Top 7MGTE
Igknyte is offline   Reply With Quote
Old 09-06-2009, 04:52 AM   #3
btwilson86
Super Moderator
btwilson86's Avatar
Haha, reading this thread reminded me mine didn't work. Just fixed it, turned out to just be a couple of bad grounds.
Old 09-06-2009, 05:53 AM   #4
Igknyte
Igknyte's Avatar
bad grounds? if you use a multimeter what should i be checking continuity? it would be so nice for my dome to work... esp at nights.. lol
Old 09-06-2009, 06:28 AM   #5
btwilson86
Super Moderator
btwilson86's Avatar
Don't wanna hijack this thread, so check out the one I made on the subject Here
Old 09-07-2009, 05:13 PM   #6
brad88supra
brad88supra's Avatar
brad88supra is on a distinguished road
make sure you got a good connection with the source, me and my dad just had to fix mine yesterday because of a bad connection
1988 N/A Supra, 5 speed, Targa top, Tems
brad88supra is offline   Reply With Quote
Old 09-08-2009, 12:20 AM   #7
ynnek
Default Thanks for the replies
After doing some reading on this forum & some actual investigation, I realize I have a few more minor issues:
  • Stuck VSV valve, no heat
  • Climate control fan only works on Hi speed
  • Gear shifter is very loose
  • Hood & hatchback shocks need to be replaced
  • power antenna not working, maybe it is just not hooked up as there is a Pioneer head unit installed
  • Clunking noise when turning sharply
  • Needing an alignment, maybe due to the previous symptom
  • Rear transmission mount shot
  • Eratic speedometer cable
  • Driver seat has a lot of "slack" in it.
Well it looks as though I have my work cut out for me. I will get all of the minor things fixed, then have the dent pulled on the quater panel & have it painted back to the factory color. Stay tuned & I will update all of my progress.
just bought a 1993 mkiv twin turbo, need help 1993suprawr MKIV Supra 66 10-10-2008 11:16 PM
just bought a super dupra, noob to the car bleSId MKII Supra 18 04-02-2008 06:36 AM
just bought supra black_knock313 MKIII Supra 2 06-29-2006 07:33 AM
Im new here.. just bought an 88 na supra Gee-oob MKIII Supra 5 09-30-2005 12:21 AM
