Old 08-10-2005, 12:09 AM   #1
Intenseneal
Guest
Posts: n/a
I just compression check my JDM 7MGTE motor and got 150-160 psi for all 6 cylinders. My repair manual says that stock compression should be 142 psi per cylinder. I have stock internals and a Greddy 1.5mm head gasket and have not had the block of head milled. What could be causing such a high compression check, not that I'm complaining.
Old 08-10-2005, 04:11 AM   #2
Poodles
Poodles is on a distinguished road
Seems to be the norm for having a metal head gasket by what I've seen on these forums. As long as you don't detonate...
Poodles is offline   Reply With Quote
Old 08-10-2005, 04:52 PM   #3
Intnesneal
Guest
Posts: n/a
What seems to be the norm, the metal head gasket or the high compression from having a metal head gasket. Every one that has a 7M know you need a metal head gasket.
Old 08-12-2005, 02:59 AM   #4
Poodles
The increased pressure with a MHG SEEMS to be the norm. Did you have a valve job done or anything while the head was off? Valve can decrease the size of the combustion chamber bumping up compressions too
Old 08-14-2005, 12:56 AM   #5
Intenseneal
Guest
Posts: n/a
No no valve job, stock internal motor.
Old 08-15-2005, 10:27 AM   #6
suprra_girl
7M POWAH! ;)
suprra_girl's Avatar
stock compression is 142psi or more
no more of a variance than 14psi per barrel
so as long as they're even
ya good
Pics of my build.
Do a diagnostic first!
Question about 7m-gte. AzNbOi2626 MKIII Supra 3 03-29-2011 06:55 PM
compression test question mastergrader007 MKIII Supra 2 08-09-2008 12:05 AM
Compression check question... Serge MKIII Supra 2 04-07-2008 03:49 AM
Compression and Block Tests mrnickleye Supra FAQ 0 01-29-2007 03:49 AM
looking at a 90 turbo with compression problems jtitzer56 MKIII Supra 1 09-23-2006 05:27 PM
