Guest
Posts: n/a
I just compression check my JDM 7MGTE motor and got 150-160 psi for all 6 cylinders. My repair manual says that stock compression should be 142 psi per cylinder. I have stock internals and a Greddy 1.5mm head gasket and have not had the block of head milled. What could be causing such a high compression check, not that I'm complaining.
Seems to be the norm for having a metal head gasket by what I've seen on these forums. As long as you don't detonate...
Guest
Posts: n/a
What seems to be the norm, the metal head gasket or the high compression from having a metal head gasket. Every one that has a 7M know you need a metal head gasket.
The increased pressure with a MHG SEEMS to be the norm. Did you have a valve job done or anything while the head was off? Valve can decrease the size of the combustion chamber bumping up compressions too
Guest
Posts: n/a
No no valve job, stock internal motor.
#6 |
stock compression is 142psi or more
no more of a variance than 14psi per barrel so as long as they're even ya good ![]()
Question about 7m-gte. | AzNbOi2626 | MKIII Supra | 3 | 03-29-2011 06:55 PM |
compression test question | mastergrader007 | MKIII Supra | 2 | 08-09-2008 12:05 AM |
Compression check question... | Serge | MKIII Supra | 2 | 04-07-2008 03:49 AM |
Compression and Block Tests | mrnickleye | Supra FAQ | 0 | 01-29-2007 03:49 AM |
looking at a 90 turbo with compression problems | jtitzer56 | MKIII Supra | 1 | 09-23-2006 05:27 PM |
