Old 09-11-2009, 09:06 PM   #1
donkey
donkey is on a distinguished road
Question Intake Valves Clearance Adjustment question
Reposting cause this question was buried in an old thread:
I just brought my 1990 NA into a shop for a leaky valve cover gasket replacement and valve clearance adjustment. After measuring the clearance, the mechanic found 3 intake valves out of adjustment (two on one cylinder). All were too tight, and the worst was 1/2 the minimum spec. He says these intake valves are always out of adjustment b/c of carbon deposits built up under the valve. He says the only way to solve it is to try fuel injector cleaner (Redline) or remove the head. Is he right? Is the whole Toyota recommended shim measurement and replacement procedure to adjust intake valve clearances just a crock of shit when it comes to these engines (7M-GE)? I've been running my car on E85 (with modified injector pulses to richen the mixture) for the last 6000 miles, so I find it hard to believe I would have carbon deposits under my valves. The head has 136000 miles on it, and the short block about 36000.
thanks in advance.
1990 Toyota Supra, NA, 7MGE, Automatic
donkey is offline   Reply With Quote
Old 09-14-2009, 02:45 AM   #2
mikeoc1
mikeoc1 is on a distinguished road
Just fix the clearance with new shims and not worry about what the mechanic says. I just did my valve clearances last week. I had 18 of them totally out of whack. Easily fixed by following the toyota method in the service manual. Made a huge difference in how my supra ran. Nice and quiet now and running well. Some of mine had no clearance some were over a mm to much. your mechanic probably just doesnt want to bother with doing the calculations and such and order the new shims. A little time consuming but neccesary.
mikeoc1 is offline   Reply With Quote
Valve Clearance adjustment gorillaguy8 MKIII Supra 5 09-03-2009 09:17 PM
Cleaning Intake & Injectors mrnickleye Supra FAQ 6 03-23-2007 04:26 AM
Another Intake Question scruffboy Non-Generation Specific Questions 9 07-15-2006 09:17 PM
intake manifold question kikwear002 MKIII Supra 3 01-03-2006 03:01 AM
