Old 09-14-2009, 07:06 PM   #1
lacrosseg64
lacrosseg64 is on a distinguished road
Default Air Filter install
So my bud gave me an after market filter cus he owed me some money, but all i got was the filter... Im pretty sure i need something to mount it to. Any advice or anything would be nice. thanks
lacrosseg64 is offline   Reply With Quote
Old 09-15-2009, 02:21 PM   #2
87mk111
87mk111's Avatar
All you really need is a hose clamp. Unbolt the stock air box and remove it. Then insert the new filter into the stock pipng. Then put a hose clamp around the intake piping to keep the filter from going anywhere.
Old 09-15-2009, 05:46 PM   #3
btwilson86
Super Moderator
btwilson86's Avatar
Is it a cone filter? If so, you'll need to unbolt the stock air box from the mass air flow sensor. Buy a MAF Sensor adapter (eBay, or your local auto parts store. You may need to drill new holes). Install the air flow sensor adapter on the MAF, slide a hose clamp around the base of your filter, and pop the filter on the adapter. Tighten it down, and you should be good to go.
For stability reasons, it'll be a good idea to leave the one bolt and bushing that bolts the MAF sensor to the inner fender, that way your filter won't slide into any of your belts or anything.
Product Review: AEM Dry Flow Filter 3" by 5" mkiiisupra Shops & Part Reviews 4 01-15-2010 02:15 AM
K&N Air Filter D_Train MKIII Supra 6 01-04-2008 07:27 PM
1991 Non-Turbo Supra: Use of K&N air filter to boost hp and mpg? unkymurch Non-Generation Specific Questions 2 04-02-2007 04:36 PM
