Old 09-17-2009, 10:06 PM   #1
oheylnaishca
oheylnaishca is on a distinguished road
Default 7mgte wont idle properly*video*
Ok so here it goes last week we had the car running fine...timing was perfect and cam position sensor was fixed then a week later we started the car again and it wont idle the car turns on and just dies here's a video of the car and there is also a coolant leak somewhere and oil leak..but no vacumm leak
oheylnaishca is offline   Reply With Quote
Old 09-18-2009, 02:17 AM   #2
oheylnaishca
okay heres what ive done so far checked the codes and cleared all of it I had code 51 i was able to clear that code by splicing the IDL and e2 on the TPS harness and it showed up code 41 so tomorrow morning im going to check for resistance on the two bottom tps and ill post up more stuff and also the leaking was coming from a coolant line i just need to find it...no oil leak
won't idle 3.0trd MKIII Supra 6 06-15-2009 07:23 PM
need help with 7mgte idle problem MAG.net MKIII Supra 4 09-06-2007 06:10 AM
7mgte ENGINE IDLE PROBLEM>>>>>HELP PLEASE pei09 MKIII Supra 4 03-27-2006 04:50 PM
