Old 09-29-2009, 05:11 AM   #11
btwilson86
Super Moderator
btwilson86's Avatar
Never messed with the fuel tank, so I can't help you there.
You can insert the paperclip with everything connected, all your doing is putting power to the fuel pump circuit (don't worry, it's a low power circuit; won't even spark or anything). You should hear fluid flowing around your intake manifold, as your fuel rail is underneath the part of the intake where the "Y" pipe bolts to the rest of the intake manifold. You can also have somebody listen by the fuel door with the cap off and see if they hear a humming sound when the jumper wire (paperclip) is connected.
Old 10-12-2009, 11:14 PM   #12
Krem
Update:
Found my problem, was a broken distributor shaft down near the gear... at least I hope that's all that it was...
new member with 1990 turbo! Slofo Non-Generation Specific Questions 4 02-12-2008 05:46 AM
A few quirks and concerns i could use help. Kuban MKIII Supra 2 02-03-2007 10:47 AM
New Member :] chroN-_^ Non-Generation Specific Questions 6 01-20-2007 10:57 PM
anybody a member of cygnus x1 site ? bennyboy55 MKIV Supra 1 10-25-2006 06:22 PM
1984 MkII front cross member needed barton MKII Supra 3 04-12-2006 04:05 PM
Copyright ©2000 - 2024, vBulletin Solutions, Inc.
