Old 09-19-2009, 02:50 AM   #1
Raysupra
Raysupra is on a distinguished road
Default New Turbo not working with ECU.
The 60-1 is suppose to produce more Hp and faster spooling. I couldn't run it on my project due to the stock CPU, it would cause the CPU to go into Limp mode as soon as it detected the extra boost. Its the upgraded ct-26 , Anyone Got any ideas whats exactly causeing the limp mode Ive heard like maf sensors or the ecu freaking out due to the boost going way over the stock 8psi and atf ratio changing to much and the ecu forcing the orignial fuel mapping... how do i get the extra boost without the limp mode kicking in?
Raysupra is offline   Reply With Quote
Old 09-25-2009, 04:17 AM   #2
Are you still running the stock injectors? Get bigger injectors, a wideband and a fuel controller.... then, tune!
Turbo Gauge not working? ravenmaster MKIII Supra 2 02-22-2008 10:33 PM
