Old 09-20-2009, 10:49 PM   #4
cbrewster
cbrewster's Avatar
cbrewster is on a distinguished road
Smile
Thanks for the replies...I took the spark plugs out when I first noticed the engine was struggling to turn.
I am starting to suspect that the transmission is the cause of the problem. I had a lot of trouble installing the transmission because I could not get it lined up properly. I borrowed a transmission jack (something I should have done in the first place) and I plan on taking it out and seeing if that frees up the crank shaft. If this doesn't work, then I will try checking the timing belt, cam gears, crank pulley, etc.
I sure hope one of these two methods will fix the problem...if not, then I might have a car available for parts! I will let you all know what the progress is. Thanks again!
__________________________________________________ _______
87' Toyota Corolla (I put 250k miles on this car) ~ Sadly Traded
98' Toyota Tacoma SR5 Ext-Cab ~ Driver
88' Toyota Supra with an 87' 7mgte; 3" exhaust ~ Restoring
cbrewster is offline   Reply With Quote
high speed(rpm) engine cuts out??? help!!! krahs912 MKIV Supra 3 08-14-2009 11:21 AM
