Old 09-28-2009, 03:45 PM   #11
86.5 7MGE
86.5 7MGE's Avatar
Originally Posted by nu_supra04 View Post
but the plugs are only two weeks old, do i still have to replace them?
You want to check to see if they are blown n look like they need to be replaced...but if they are covered in oil most likely they have fawled out and need to be replaced if not your going to have poor performance and gas mileage.
Cold Air Intake
MIZU Aluminum Radiator
Ralco RZ Underdrive Pulley
NGK Wires and Plugs
Hi Flow CAT
MR Muffler
Super Coil
Techna Fit Brake lines
Clear Corner Turn Signal Lens
Projector Head Lights
Evo Fog Lights
Evo Body Kit
Soon ---> 3'' Exhaust
Old 09-28-2009, 03:46 PM   #12
oregonjoe
oregonjoe's Avatar
Default Plugs
Plat tip plugs can not be cleaned - standard ones can but not recommended. Replace them
If oil on Both sides meaning tips - could be when they were removed they were contaminated from top oil – that’s what happened on mine. If tips are dark and burned with lots of deposits then probably leaking valve seals or bad rings
Spark Plugs and Water cgreiner MKIII Supra 1 07-21-2009 03:49 AM
Spark Plugs (1G-GE vs 7M-GE) makemedie Non-Generation Specific Questions 5 10-26-2008 05:19 AM
NGK Spark Plugs 91 Supra MKIII Supra 5 08-07-2007 03:52 AM
1986.5 with blown Head Gasket - Removing Spark Plugs unkymurch Non-Generation Specific Questions 10 03-02-2007 06:48 PM
Issues After Changing Spark Plugs Getphazed MKIII Supra 8 11-03-2006 12:31 PM
