Old 09-25-2009, 07:56 AM   #1
nu_supra04
nu_supra04 is on a distinguished road
Default oil with spark plugs don't mix
so i just recently bought a 1990 supra turbo with about 120500 miles on it, i plan to keep the body pretty much untouched unless for paint but I'm planning on definitely adding a a lot of power to. so i right now i got two questions, i recently read that getting a divorced downpipe adds hp so can anybody explain who that works??
also i was recently changing the spark plugs and as i took the old ones out some were covered in oil, any ideas to what is causing that?
any help appreciated thanks
nu_supra04 is offline   Reply With Quote
Old 09-25-2009, 04:47 PM   #2
oregonjoe
oregonjoe's Avatar
Default Oil on plugs
The 4 plugs on the NO3 Oil Cover are leaking - very common.
Its the black plate over the plugs.
They go right to the valves.
Put Oil plug washers on them and RTV
There is a geat sticky on this topic on the MKIII form
Old 09-25-2009, 06:46 PM   #3
nu_supra04
ok thanks
btw what does rtv mean? kinda new here
Old 09-25-2009, 07:40 PM   #4
Krem
looking across the net, closest match I found for RTV was "Rotary Throttle Valve"... but I'd imagine that's something I'd find in a Mazda... not a Toyota... then again, a lot of things rotate in an engine block... so perhaps someone more mechanically enclined could confirm or say what it means..
Old 09-25-2009, 08:46 PM   #5
Bill UK
AEM EMS
Bill UK's Avatar
Room Temperature Vulcanising (RTV). Silicon Sealant or I would recommend this product if you can get it in the US. Link it has the consistency of maple syrup and never dries, recommended by vintage car builders developed for Rolls-Royce.
Old 09-25-2009, 11:10 PM   #6
nu_supra04
Thanks
is it a problem that has to fixed immediately?
Spark Plugs and Water cgreiner MKIII Supra 1 07-21-2009 03:49 AM
Spark Plugs (1G-GE vs 7M-GE) makemedie Non-Generation Specific Questions 5 10-26-2008 05:19 AM
1986.5 with blown Head Gasket - Removing Spark Plugs unkymurch Non-Generation Specific Questions 10 03-02-2007 06:48 PM
Issues After Changing Spark Plugs Getphazed MKIII Supra 8 11-03-2006 12:31 PM
