Old 09-28-2009, 04:50 AM   #1
dupra87
dupra87 is on a distinguished road
Angry mbc problems
hi i have a 87 supra. im new to the turbo set. so heres my question. i put a mbc on it, and no matter what i do i cannt change the boost. ive tried eveything i can think of. please any info will help. im sure there is no leaks or anything like that.
dupra87 is offline   Reply With Quote
Old 09-28-2009, 10:45 PM   #2
DarkSupra2.5
DarkSupra2.5's Avatar
DarkSupra2.5 is on a distinguished road
Well, how'd you install it? controller between the wastegate and compressor side of the turbo properly?
1jz-gte swap (Currently spun #3 rod bearings), Apexi high flow filter, Greddy thrust 3" downpipe, N1 3" catback with cat delete tube, 1 peice driveshaft, Bar and Plate intercooler, and 440 JDM 2jz injectors.
Possible 2jz lower block swap in the works if I can't rebuild the 1j. So troublesome.
DarkSupra2.5 is offline   Reply With Quote
Old 09-30-2009, 02:28 AM   #3
dupra87
Default mcb problems
thanks for reaplying. but ya it installed just a few different peps say on the forum too. ive tried every way but the right way. i know the controller works. i can blow air into as i turn and it works. i dont know dude fustrates me.
Old 10-01-2009, 12:24 AM   #4
DarkSupra2.5
if you can, pm me a pic of how you have it installed and I should be able to help you out ok? No need to stress, it'll get fixed ya kno?
Old 10-03-2009, 05:13 AM   #5
dupra87
Default repply
i cannt send a pic not to sure how to anyways. im just going to play with it alittle bit more. if i cannt figure it out, ill just take it out. no biggy. i just shimmed it anyways so well see if that will aleast get me to 11 psi anyway thanks though i apprate it.
problems problems problems.... 86SupraMan MKIII Supra 5 02-04-2008 04:28 PM
Starting problems and accleration problems! alekjame22 MKIII Supra 6 03-17-2007 11:19 PM
Oil leak problems adellicson MKIII Supra 1 03-04-2007 10:11 PM
random dying problems (1989 n/a) thechori MKIII Supra 11 11-06-2006 05:03 AM
problems, problems, and problems tone loc MKIII Supra 6 09-06-2006 04:35 AM
