Old 09-30-2009, 04:46 AM   #1
89_1j
89_1j is on a distinguished road
Default 2jz fuel pump on 1jz
hey everyone, id like to put a 2jz fuel pump on my 1jz. Is that a direct bolt-on upgrade or are there any modifications/alterations required?
89_1j is offline   Reply With Quote
Old 09-30-2009, 01:45 PM   #2
DarkSupra2.5
DarkSupra2.5's Avatar
DarkSupra2.5 is on a distinguished road
Techinically, if it's just the pump, it should drop right in, considering it's just a electric motor anyway, the car won't notice the difference, tho your motor will .
1jz-gte swap (Currently spun #3 rod bearings), Apexi high flow filter, Greddy thrust 3" downpipe, N1 3" catback with cat delete tube, 1 peice driveshaft, Bar and Plate intercooler, and 440 JDM 2jz injectors.
Possible 2jz lower block swap in the works if I can't rebuild the 1j. So troublesome.
DarkSupra2.5 is offline   Reply With Quote
Old 10-01-2009, 06:52 PM   #3
2jzmaestro
2jzmaestro is on a distinguished road
i believe their will be a differenece because the 2jz fuel pump supplies enough gas to maintain the motors speed and the Twins turbos which means it would be bigger than your stock 1jz one, only problem that might take place is that it might jst flood your engine because your car wouldnt be burning the gas quick enough.
2jzmaestro is offline   Reply With Quote
Tags
1jz, 2jz, fuel, fuel pump
no power to fuel pump carcrzy920 Non-Generation Specific Questions 0 06-05-2009 05:51 PM
fuel pump mounting bracket GremlinMKIII MKIII Supra 4 09-06-2007 07:08 AM
MSD fuel pump? redmaro MKIII Supra 6 08-24-2007 04:09 PM
Testing for bad ECU, &/or bad Fuel Pump elliotl MKIII Supra 0 08-21-2007 10:42 PM
Fuel pump hanger for 87 supra non turbo rlipp69 Non-Generation Specific Questions 0 06-16-2007 03:23 PM
