Old 09-30-2009, 05:57 PM   #1
86.5 7MGE
86.5 7MGE's Avatar
Exclamation 86.5 7MGE Problems
OK, so I'm starting to think that I have a BHG. My symptoms include...radiator fluid spraying out constantly from the purge port on the reserve and when I drive sometimes not all the time it will start hesitating while the accelarator is pressed. It seems that I have to fill up the radiator every two days or so because of all of the fluid being purged out. I had Pepboys do a pressure check on my coolant system and they said it was my radiator cap at fault. So, I replaced all of my coolant hoses and vaccum lines to include the radiator cap and thermostat...is there something else that I can try that I'm missing before I assume that it's a BHG??? I still seem to have great power and only powerloss when my radiator gets low on coolant or it starts to hesitate.
At the same time I see traces of black smoke on my rear bumper and I know that white steam/smoke is a sign of a BHG due to coolant mixing in the combustion chambers. Could this be also from worn out piston rings?
Cold Air Intake
MIZU Aluminum Radiator
Ralco RZ Underdrive Pulley
NGK Wires and Plugs
Hi Flow CAT
MR Muffler
Super Coil
Techna Fit Brake lines
Clear Corner Turn Signal Lens
Projector Head Lights
Evo Fog Lights
Evo Body Kit
Soon ---> 3'' Exhaust
86.5 7MGE wont start , no spark Spitfire_Fox MKIII Supra 6 06-24-2011 03:25 PM
7MGE ECU problems grabber MKIII Supra 2 06-10-2009 10:53 PM
86.5 7MGE supra smog test fails googoogaga Non-Generation Specific Questions 7 10-18-2006 02:44 AM
fuel problems in 86.5 86.5mkiii MKIII Supra 3 09-18-2006 10:00 PM
problems, problems, and problems tone loc MKIII Supra 6 09-06-2006 04:35 AM
