I was wondering what kind of oil pressure readings everyone gets from their stock oil pressure gauge. Please note if the car is turbo or not.
After i start up my 86.5 7mge and drive for about a minute I hold a steady reading of 40lbs after the car gets to the right temperature i hold about 20lbs when I am driving at 2000rpms and if I'm idling it can drop to anywhere from 10lbs to 0lbs |
2kg/cm cubed (canadian) at 2 thousand rpm for my 1988 na
#3 | |
![]() Quote:
![]() in short, I think you're good... you can look into changing oil weights... I believe that effects the oil pressure too... the change in oil pressure has to do with temperature and pressure under load.. from my understanding anyways.. |
thanks for the info. I think I am going to flush the motor soon and replace the oil pan so when I do that i will check for leaks but my car was sitting for a month and I didn't notice any leaks either.
lemme know how that works for you... if it makes a difference on the pressure... cause if so, I might have to fork out the money to drop the suspension and lower the oil pan and get 'r done.. too bad can't just drop the oil pan normally...
Oil Pressure? | supraguy | MKIII Supra | 3 | 09-16-2009 08:35 PM |
What is wrong with my oil pressure? | jSoUhPnRA92 | MKIII Supra | 1 | 08-31-2009 06:17 AM |
7MGE oil pressure | Arne (Denmark) | MKIII Supra | 14 | 07-31-2009 10:07 PM |
Clutch & Pressure Plate—Interchangeable b/t years and W55/W58? | jhealey1967 | MKIII Supra | 5 | 03-25-2009 08:00 AM |
Fuel pump relay and pressure. | carfanatic89 | MKIII Supra | 8 | 05-01-2008 06:39 PM |
