Old 10-16-2009, 04:29 PM   #1
jcastro
Default turbo/sonser help
Im thing about buying a rebuit turbo from ebay but im not sure iv herd bad stories about them here it is let me know wut u think http://cgi.ebay.com/ebaymotors/T61-T...Q5fAccessories
also i dnt know what this sensor is its located on the thermostat housing its the therid one on the bottum thanks for all the help u guys sure save alot of time and help out alot
jcastro is offline   Reply With Quote
Old 10-18-2009, 07:40 AM   #2
There's an ongoing thread about the quality and reliability of this turbo here: http://www.supramania.com/forums/sho...d.php?t=102040
One thing that is backed by the opinions of some VERY knowledgeable people is that this turbo should absolutely NOT be run with the stock elbow (the 90? bend with the O2 sensor mounted in it that's mounted to the back of the turbo).
You only have 2 sensor locations on the thermostat housing? If so then I presume it's because your car is an '88 or older. The three position thermostat necks was on '89 GTEs and newer if I recall correctly.
Here's what the sensors are and their locations:
Old 10-18-2009, 08:54 AM   #3
jcastro
thanks man
