Old 10-23-2009, 09:24 AM   #1
Tony
Tony is on a distinguished road
Default Help! Post-rebuild engine problems!
Hey everyone,
I bought my 88 Supra Turbo with a BHG a while back, and have since done the following to it:
New HG and upper gasket set
ARP Bolts (70ft/lb)
Different turbo head purchased (old was warped .020")
Head machined flat, checked, and valves reseated
Set of completely refurbished fuel injectors (ultrasonically cleaned and flow tested)
Vacuum systed completely gone through and everything is properly connected.
Also tested every coil pack for spark (looked for spark in a removed plug attached to each coil pack)
Feels like a cylinder or two isn't firing.
Here's a video (don't mind the squeak, alternator belt is not tensioned all the way)
http://www.youtube.com/watch?v=1BudtjtPh70
The car starts but runs terribly, once the RPMs go past 2500, all power is lost until it drops below that.
If you keep the accelerator floored, it will go up past 2500 RPMS, then fall back to it over and over.
Can someone help me?
I want to get this thing on the road!
Tony is offline   Reply With Quote
Old 10-24-2009, 12:09 AM   #2
Double check the mechanical timing (crank, cams and CPS), if that's all square, check the ignition timing.
Any error codes?
Old 10-24-2009, 01:46 AM   #3
i agree chek the error codes...
simple and a start...
Old 10-24-2009, 03:05 PM   #4
86.5supra
86.5supra is on a distinguished road
your getting a fuel cut out my 7mgte did it after we had it rebuilt. after they tore the motor back apart we found out that it was a O2 sensor that was fucking up the computer.
86.5supra is offline   Reply With Quote
Old 10-24-2009, 03:53 PM   #5
not tryin to topic steal, but how many sensors does the engine have (for a non turbo)
i wouldnt mind getting all mine checked
Old 10-24-2009, 06:24 PM   #6
ricerbaby
ricerbaby is on a distinguished road
having the same problem at the moment.. my 88 is doing the same thing. it sounds just like a computer problem, i had a broken coolant hose and it threw coolant and water all over the engine and it got in my cpu which made my car do the same thing. a new cpu unit is pretty expensive... but you can look for one on ebay too...
ricerbaby is offline   Reply With Quote
7MGE Engine rebuild oregonjoe MKIII Supra 69 03-23-2010 02:12 AM
7MGE Engine Rebuild SilenceboneSupra MKIII Supra 1 10-23-2007 06:45 PM
PLEASE help newbee with engine rebuild canadian mole MKIII Supra 4 06-17-2007 01:01 AM
1988 supra engine rebuild 1988Suprakid MKIII Supra 5 06-07-2006 09:07 PM
New Engine Or Rebuild Help ! ! ! ! ! DarkRaiderz MKIII Supra 5 01-23-2006 01:21 AM
