Old 11-09-2009, 05:57 AM   #11
VERY nice... 850s? how far are you trying to go with this build? Looks great so far.
Old 11-09-2009, 07:49 AM   #12
two-step-n
i dont no yet lol
Old 11-13-2009, 02:52 AM   #13
two-step-n
with the standalone i can tune the 850's down so i didnt wanna buy a bigger size later on down the road!
Old 11-13-2009, 03:13 AM   #14
This is for the benefit of other readers, not yourself two-step-n.
Keep in mind that you can only pull so much from the injector duty cycle before you have to start reducing fuel pressure; Too little fuel pressure and the injector spray pattern goes to hell. I'm sure you'll be able to tune it decently, just making sure you've considered it. No biggie on a track car, but it does happen that people go too big and find that the minimum flow required for a clean spray pattern isn't really streetable anymore. I know there are people running MoTeC's with even larger injectors though. Each EMS has its limitations and you need to keep them in mind when building.
EDIT: BTW, I do hope you actually make use of the full capability of those... that'll be one hell of a beast!
Old 11-13-2009, 04:08 AM   #15
evosupra
Banned
Originally Posted by two-step-n View Post
the new rc 850's!
Nice clean job !
Name:	engine powder coat.jpg
Old 11-13-2009, 05:07 AM   #16
So what EMS are you going with anyway?
Old 11-13-2009, 05:17 AM   #17
two-step-n
an aem ems
ID:	2563   Click image for larger version
ID:	2564   Click image for larger version
ID:	2565   Click image for larger version
Old 11-13-2009, 05:18 AM   #18
two-step-n
Originally Posted by evosupra View Post
Nice clean job !
i like the power coat looks clean
Old 11-13-2009, 06:43 AM   #19
86.5 7MGE
86.5 7MGE's Avatar
It looks great so far... Let me know how that AEM EMS works out for you because I am considering on purchasing one in the near future
Cold Air Intake
MIZU Aluminum Radiator
Ralco RZ Underdrive Pulley
NGK Wires and Plugs
Hi Flow CAT
MR Muffler
Super Coil
Techna Fit Brake lines
Clear Corner Turn Signal Lens
Projector Head Lights
Evo Fog Lights
Evo Body Kit
Soon ---> 3'' Exhaust
Old 11-13-2009, 06:52 AM   #20
two-step-n
my friend has a 88 toyota pick with a 7mgte swap we plugged the aem ems into it with a stock tune and wow its so crazy the thing you can do and so ez to uses make sure you get the plug-n-play tho unless you wanna do alot more work to install. its really cool all the settings and maps its nuts
Engine build... h8z2luze MKIII Supra 5 12-08-2006 03:55 AM
