Old 10-27-2009, 01:07 AM   #1
bdhs03
bdhs03 is on a distinguished road
Default 1986 supra HELP!!!!!!!!!!!!
i just traded my 91 civic for a 86 supra straigt up and well i know i have a lot of work i have the 7m non turbo and well i am having trouble getting parts and theni dont knopw where to start or what to do i was thinkin about a 2jz swap but all i want is a 600hp at the rear wheels i am thinkin about a turbo but idk the most importent is to be relibal it will be my daily driver in the summer where do i need to start what do i need to do please help thank u
bdhs03 is offline   Reply With Quote
Old 02-10-2010, 06:35 AM   #2
DarkSupra2.5
DarkSupra2.5's Avatar
DarkSupra2.5 is on a distinguished road
Bein honest, you should decide how much you're willing to spend on your car. Your 7m can pull out a reliable 600 with a turbo kit, exhaust mods, and fuel mods (Along with essential odds and ends). A 1jz is the next easiest engine to drop in the MKIII supra in my opinion. Then it would be the 2jz. going with a stand alone ecu system would make any engine really easy to drop in the supra as well.
In the end, any Supra engine can make 600 rwhp reliably and be streetable. Legal, that's iffy depending on where you live, but whatever engine you want to go with can do it. But it's not cheap. Good luck.
1jz-gte swap (Currently spun #3 rod bearings), Apexi high flow filter, Greddy thrust 3" downpipe, N1 3" catback with cat delete tube, 1 peice driveshaft, Bar and Plate intercooler, and 440 JDM 2jz injectors.
Possible 2jz lower block swap in the works if I can't rebuild the 1j. So troublesome.
DarkSupra2.5 is offline   Reply With Quote
Old 02-10-2010, 11:42 PM   #3
kamikazemkiii
kamikazemkiii is on a distinguished road
Do research, theirs plenty of threads on this on other forums. Have you driven a car with 400hp?
You need a good fuel system, standalone, turbo kit, just to name a few. Having 600hp calls for alot of things and even more money.
kamikazemkiii is offline   Reply With Quote
1986 supra problems brossini MKII Supra 1 09-18-2008 06:49 AM
